76 F250 Specs Decoded
Oct 22, 2006 | 08:45 AM
Was wondering if someone could help determine the specs on this pickup.
I did my best reading the tag.
Vin: F26YLB93179
Type/GVW: F260
Body:BB4
Trans/AXL: G24J
GVW: 6850
Color:A
WheelBase: 133
Now I think it's a 76 F250, 360 motor, Dana 44 Front / Dana 60 Rear, NP203 T/C, C6 Trans., Full time 4X4
Any Idea what this is worth? Box is junk, cab mounts are gone, Frame is average, motor runs and the pickup drives and shifts. 75,000 origional miles.
Thanks for the help.
Oct 22, 2006 | 02:37 PM
Vin: F26YLB93179
F26- F250 4x4
Y- 360
L- Michigan Truck Plant
B93179 - consecutive build number -March 1976
Type/GVW: F260
F250 -6850 lbs
Body:BB4
B- Vinyl standard bech seat
B- Blue interior
4 - styleside box
Trans/AXL: G24J
G- C6 auto
24 - Dana 60 4.10 (5300 lbs)
J- power steering
GVW: 6850
Color:A
A - Black
WheelBase: 133 133"
Oct 22, 2006 | 02:42 PM
Thanks,
The front axle looks like a Dana 44, would that dana 60 thats spec'd out refer to the rear axle?
It must be a NP203 T/Case? It's a full time 4x4.
Oct 22, 2006 | 07:03 PM
On the D44 is it a hi pinion or low pinion?
Oct 22, 2006 | 07:55 PM
I think it's a high pinion dana 44, however I'm not sure. I had a 79 with a Dana 60 and this looks different. The Dif cover bumps out for the ring gear. I was hoping someone could tell me for sure by the vin number.
Oct 22, 2006 | 07:57 PM
I've got a 77 1/2 ton and the front axle's different on that too.
Oct 22, 2006 | 08:12 PM
Remember many of these trucks have had parts "exchanged" over the years. Unless there is a lot of service paperwork that shows a continuous paper trail documenting mileage over time then that 75K showing on the speedo may be 175K or even 275K miles.
Oct 23, 2006 | 01:04 AM
Quote:
The VIN# doesn't contain any info about the axle.
What I didn't know from memory .....I got the info I posted right from the 76 Ford Truck Manual.
Oct 24, 2006 | 08:05 PM
The more I looked into it, I now think it is a Dana 60. Thanks for your help, Any guess as to the value of the pickup?
V8SHO
Jan 12, 2017 01:57 PM
rangernut09011980
Mar 31, 2015 12:47 PM
schoo
May 23, 2013 07:01 PM
F100 Girard
Nov 5, 2012 05:41 AM
amchastain
Jul 23, 2005 09:44 PM
