Interior Lamp relay Buzzing
Old Oct 21, 2006 | 11:56 AM
jeff_E's Avatar
jeff_E
Anyone ever have a problem like this:
When driving in a fierce rainstorm, my interior lights came on and the interior lamp relay started buzzing. When I shut the truck down it all went away, but in the am the batteries were completely drawn down. When I do get it started the buzzing continues except on the odd occasion that I close the driver side door just right, but then it comes back.
Questions:
1. Where would you start to find the short
2. Is it Ok to drive with the relay pulled out?
Regards,
Jeff
Old Oct 22, 2006 | 02:57 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Sounds like the problem could be a wet switch.....maybe in the drivers side door. You might try soaking the door latch/switch with some WD-40.
Thread moved.
Old Oct 22, 2006 | 07:53 PM
Franklin2's Avatar
Franklin2
I don't know what year truck you have, but if it's a later model, they were plagued with windshield leak problems. And the leak would run down into the GEM module which controls all the functions you describe.
Check the flooboard and see if it's wet. The GEM module and the fuse box are mounted on the inside firewall, so look for signs of water. The fuse box can be wet too from the leak.
sargentmajord
Mar 9, 2014 01:09 PM
travisg96
Jan 28, 2014 10:59 AM
cutlass
Jan 3, 2013 11:25 PM
zpcg05
Electrical Systems/Wiring
Jul 3, 2008 03:16 AM
beerguy5812
Dec 11, 2005 11:15 PM
