diesel stack set up
Old Oct 20, 2006 | 06:06 PM
Epd444's Avatar
Epd444
diesel stack set up
I'm lookin into purchasing a set of 7'' stacks, but every kit i see has one hole drilled in the bed with the Y pipe inside the bed. Anybody know of any kits where it is 2 seperate holes drilled into the bed, so the Y pipe is not visible.
Old Oct 21, 2006 | 06:46 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
you could do that if you modified the normal kit, however you would have to run the pipe under the framerails to get from between the frame to the outside of the frame on each side. this is why all the y pipes are in the beds.
Ford4Life7.3
26
Oct 28, 2016 09:05 AM
Leemakesmepee
Jul 29, 2011 05:47 AM
Krisx125
34
Jan 26, 2011 01:46 PM
1957F100
Oct 23, 2008 06:04 PM
TexasRoughneck
Jan 12, 2006 04:09 PM
