1978 - 1996 Big Bronco
water temp sensor '89 bronc
Old Oct 20, 2006 | 04:25 PM
BlznOlie95's Avatar
BlznOlie95
Cool water temp sensor '89 bronc
i have an '89 bronc inline 6 cyl 4.9L and the water temp sensor is insane and im going to replace it, i have the new sensor and gauge all the wireing all the hardware i just cant find where the sensor fits into the engine block. If anyone has ANY kind of information i would be MORE than appreciative!!
Old Oct 20, 2006 | 06:07 PM
95bogginbronco's Avatar
95bogginbronco
I work at a ford dealer and just replaced one of those on a 1992 f-150. It shouldn't be too much different. The sensor should be by the thermostat housing stick straight up.
Old Oct 20, 2006 | 06:56 PM
BlznOlie95's Avatar
BlznOlie95
where is the houseing n what does it look like?
Old Oct 20, 2006 | 09:05 PM
95bogginbronco
just follow your upper radiator house to yor engine. its right there.
Old Oct 21, 2006 | 12:28 AM
Bimmerboy1989's Avatar
Bimmerboy1989
The gauge sensor is a one wire. Look for that sensor and that will be the one. Ford equips there trucks with two different sensors. one for the computer(two prong) and one for the gauge(one prong). The gauges you bought should have an adaptor to make it fit into the spot where the stock electric gauge goes.
Old Oct 21, 2006 | 02:11 AM
BlznOlie95's Avatar
BlznOlie95
ya i have all that i just dont know where it plugs in....
Old Oct 23, 2006 | 10:31 AM
Bimmerboy1989
Know where what plugs in? In my experience I have found that aftermarket gauges are mechanical. So it has a temp sensor and a long wire that leads to the gauge. The temp sensor that is provided goes in the stock location. Then the wiring for the gauge must be ran so it turns the backlight on when the you turn on the lights. It's as simple as that.
darkhorse2011
22
Aug 10, 2020 04:09 PM
2002ford4RV
Aug 9, 2011 12:35 PM
Eric_F250
24
Mar 24, 2009 08:48 PM
masseysbronco
Jul 4, 2005 10:16 AM
b_dub
Apr 28, 2003 05:21 AM
