Engine Temp gauge quit working; Testing The Temp Sensor
Old Aug 5, 2011 | 01:45 PM
2002ford4RV's Avatar
2002ford4RV
Engine Temp gauge quit working last weekend.
I'm pretty sure it's the sensor, as I have disconnected and reinstalled the battery terminals, and when I turn the ignition key to the on position, the gauge pegged then went back to zero.<O</O
<O</O
I searched the forum, and found a post on how to test the sensor, but cannot locate again.<O</O
<O</O
Am I correct that my gauge is not the problem, probably the sensor?<O</O
Does this gauge monitor water temp (sensor above water pump)?<O</O
Can anybody tell me how to test the temp sensor (keep in mind I'm not an electrician?)
Does anybody know the part number for the sensor?<O</O
Any pictures would help.
Old Aug 7, 2011 | 09:31 PM
Neal 97 250's Avatar
Neal 97 250
Bump for some help from you SD gurus.
Old Aug 9, 2011 | 07:17 AM
Neal 97 250
Does anybody know how to test the sensor. I would imagine ohm it out but what should the reading normally be?
Old Aug 9, 2011 | 07:45 AM
hotroddsl's Avatar
hotroddsl
Neal I've looked as well and I can't find that thread either! I know I've seen it over the years but not now, sooooo........ BUMP!
Old Aug 9, 2011 | 12:35 PM
2002ford4RV
Found the post; Finally.
Pic looks like it came from a service manual? A bit blurry.<O</O
https://www.ford-trucks.com/forums/783231-coolant-temp-sensor-info-needed-gauge-not-working.html<O></O>
Ordered the sensor for about $15, assuming I've got the correct one from local dealer.
I will post the correct part # once I verify.<O</O
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
bkuuz1
Jun 5, 2014 07:44 PM
DemonRace6
19
Dec 16, 2010 11:37 AM
TucsonTripleB
Dec 17, 2009 08:24 PM
Nycer89
Jul 24, 2006 03:49 PM
