kassse scj alum heads
dose anyone know much about the kasse scj alum heads? they are the 2nd design he made i guess i am looking into a set they are nice shape only one season on them but i dont know anything about them i was gonna go with tfs but i dont have that kinda cash. and the kasse heads i can get for a good deal they havent been ported i built a 500 stroker flat top srp's i have c8ve heads now with about a 75 cc chamber i think i am at a 12-1 compression now and i am gonna put a set of upright headers with 2 1/4 tubes and 4 collector will they work with the heads or i can go with a 2 1/8 tubes? i am also gonna be running a dom 1050 carb victor intake and custom cam i want to get around 750-800 hp and run 8000 rpms on a good day i would like to know what thease heads flow and what they could flow if i got them cnc ported in time thanxs
If your talking about the current generation SCJ heads from FRPP that were a Kaase design the biggest issue is the valves are at different angles and cants so you have to recut the valve reliefs. Lunati has a tool for doing it with the pistons on the engine (Kaase did one engine on the dyno when they were testing those heads)
As far as flow here is the link to Scotts site that has the flow numbers, on the unported he just lists them as aluminum SCJ, but does list them as the Kaase heads on the ported list.
http://www.reincarnation-automotive....r-index-1.html
it almost looks like the kasse heads might be a bit better than the tfs street heads or rilly close? the guy that has the heads now ran a set of kb flat tops with a single valve cut and he didnt have to do any cutting so maybe i wont need to i have a dual valve relife srp's i think he was running a 700 lift and i am not shure what i am gonna run i am gonna go custom thou. do you think it is wishfull thinking to get 700-800 hp and 8000 rpms out of my combo?
the Kaase heads are better than the TFS street heads on the list of heads by order of performance. The Kaase heads are based off of the CJ, SCJ iron heads for intake and exhaust ports (and as such will need to have the CJ intake or have the intake port matched to it) the TFS street heads are based off of the DOVE-A heads and use the regular passenger car manifolds and are a direct bolt on replacement for your current heads with better flow numbers.
how whould i get ahold of him? and do you think i will be able to achieve 700hp and run 8000rpm's and possibly more with some porting i tihnk the heads are 72cc i was gonna clay them for clearances and see if i can shave them and get more compression i would like to get 13-1 and more but is that wishfull thinking or?
ponykilr
19
02-14-2015 08:16 PM
TexinCali
25
07-28-2014 06:22 PM
Cameo 57
04-10-2014 11:11 AM
