1978 - 1996 Big Bronco
95 Bronco Headlight Trim
Old Oct 19, 2006 | 12:54 PM
2k4gixxer's Avatar
2k4gixxer
Im trying to take the headlight trim out of the truck, so I can sand it and paint it. For the life of me, I cannot figure out how to get it out. I have the Haynes manual but it doesnt say anything about how to do it. Anyone have any suggestions?
Old Oct 19, 2006 | 03:42 PM
94 XLT White/ Silver 302's Avatar
Remove the two screws on the top of the headlight frame then on the engine side of the radiator support behind the headlights you will find an oval hole in the radiator support, in that hole is two studs mounted to the turn signal housing you have to remove the nuts on the studs then the whole assembly will come off except for the headlight lens, then remove the bulbs from the housing and your done. Repeat for the other side.
Old Oct 20, 2006 | 11:41 AM
muckypaws's Avatar
muckypaws
its not an easy task as there is so little visability and space to get your hand down but it is possible.....
bf5113x
Jan 15, 2016 04:58 PM
66ca
20
May 6, 2012 07:23 AM
Kalve
18
Mar 28, 2011 11:55 PM
fordx316
May 2, 2010 07:33 PM
chris78green
Feb 24, 2001 04:38 PM
