Aerostar Ford Aerostar
Ignition/Timing issue
Old Oct 16, 2006 | 06:39 PM
250K AS's Avatar
250K AS
Hi folks, I've been a long time gone.
Trouble on my '94 3.0. I've had a lack of power and a prominent miss upon acceleration, and a miss at speed, so I've retimed the engine (properly, 10 BTC with spout connector off). After the retime, now it pings miserably, too much advance. My first guess is that I have a bad ECU, but I don't know if this van has a seperate unit that controls advance, or is it all done in the ECU?
Any thoughts appreciated, I'm dreading going through every possible position sensor to solve this.
Old Oct 16, 2006 | 08:54 PM
96_4wdr's Avatar
96_4wdr
hi 250k as and welcome back
any chance it's carbon buildup? or a vacuum leak? or a defective plug?
all common causes of pinging preignition
how's the vacuum modulator and it's vacuum line on auto tranny?
start by pulling KOEO and KOER codes
we seldom see a Ford ECU failure, Built Intel Tough, remember?
Old Oct 16, 2006 | 09:40 PM
250K AS's Avatar
250K AS
Ha ha, good info. Oddly, I couldn't get my code reader to spit out a code. Engine off, it would start into the test, switching relays etc., but then it would be dead. No good on the run test either. I gave it a new vac mod last year, though I haven't double checked its hose now. Vac leak sounds like a good possibility. This all came on over a few weeks, van has 89K, so I doubt carbon. I'm also thinking a weak coil. Plugs are platinums, since 50K. More work tomorrow, thanks!
JP
Old Oct 16, 2006 | 11:18 PM
thefairlaneman's Avatar
thefairlaneman
Tranny vac line
I just spent alot of money one my 94 3.0 because of a disconnected vac line to the tranny. I found the line lose when adjusting the timing also.
Old Oct 17, 2006 | 12:17 AM
Pablo-UA's Avatar
Pablo-UA
It seems to me, that I have the same problem.... Puting SPOUT shoting bar out changes nothing.... So I had to retime ignition on run, to have the maximal power on 1800-2200 RPM.... Ignition is too early on low RPMs and to late on hight and iting does not depend on engine load....
I tried to chek SPOUT signal with osciloscope, and I can see it is good, and I think it is TFI failure.
https://www.ford-trucks.com/forums/5...-problems.html
Old Oct 17, 2006 | 10:59 AM
250K AS's Avatar
250K AS
My spout plug is functional. Checked tranny lines, no problem found. Removed and cleaned dist cap/rotor, the were fairly dirty. Test drive showed some improvement, but the miss was still there. Checked my TPS in run postition, showed 12V. The book says I should see 4-6V there. Whatever that should tell me, I don't understand! I'm changing the coil next, cheap enough.
Old Oct 17, 2006 | 11:27 AM
Pablo-UA's Avatar
Pablo-UA
250K! Try to do a little experiment! Remove a hatch inside the cabine, loosen bolt with 10mm wrench and try to ajust timing on run till you get the max. power and avoid pinging.
But be carefull of hight voltage and ask someone to assist you... It is difficult to drive and to look on the road.... So belive me, this is the perfect way...
Old Oct 17, 2006 | 11:51 AM
Pablo-UA's Avatar
Pablo-UA
TPS 12V???? Are you sure.... EEC-IV uses 5 volt as VREF... May be wires are shot to 12 V ore ECU is not OK.... ???
Old Oct 17, 2006 | 12:22 PM
aerocolorado's Avatar
aerocolorado
A little caution here, this may be escalating into a needlessly complex search for a simple problem.
89,000 miles, have the plug wires been replaced? If not, I would start there for sure. Also as mentioned, plugs can act up, particularly if not the correct temperature range.
Most of these problems turn out to have very basic causes but we tend to jump on the more exotic cures. Lord knows I've been guilty of this too many times in the past.
Old Oct 17, 2006 | 01:27 PM
250K AS's Avatar
250K AS
Thanks for the cool head, AeroCO! I know it's simple, just have to find it. Any normal car and I'd have already swapped wires out. Pablo, that's worked for me before. Thanks for the continued interest.
JP
Old Oct 17, 2006 | 01:35 PM
JTHill24's Avatar
JTHill24
Has anyone forgot about the Vaccum Tee/Tree ?
I guess there is still on on the 94.
Maybe it blew one, or a crack in the hose, or just too loose.
Jay
Old Oct 17, 2006 | 04:22 PM
250K AS's Avatar
250K AS
Yes, I checked the tee, nothing strange.
I can tell you it's not the coil, I just put the new one on. Timed it normal, no improvement. Next I removed the snout plug and timed it to 35 degrees @ appx. 2500. It idled OK but knocked and pinged and no power, I don't know how but it felt like it continued to advance the spark. Still had the miss too. Next is plugs and wires I suppose, and back to normal timing.
Old Oct 17, 2006 | 05:26 PM
JTHill24's Avatar
JTHill24
35 Degrees???
My three Aeros says 10 Degrees BTDC with the Spout Connector removed.
Read the label on the hood of your Aero.
JaY
Old Oct 17, 2006 | 05:30 PM
B-Aerostar's Avatar
B-Aerostar
Setting your timing to 35 degree with the spout out is too high. Try about 10 btdc and then advance it to 2 degree at a time.
Old Oct 17, 2006 | 05:35 PM
96_4wdr's Avatar
96_4wdr
can't time it that way
SPOUT disconnects dynamic spark advance by ECU...
set for 10d BTDC at idle with SPOUT removed
replace SPOUT
check timing at 3k rpm, should be around 30d BTDC
tells u that dynamic ECU advance is working based upon all sensor inputs working, MAF, IAT, ECT, crank and TPS
look for air/vacuum leak or carbon in comb. chambers
