Aerostar Ford Aerostar
Ignition/Timing issue
Old Oct 17, 2006 | 06:43 PM
250K AS's Avatar
250K AS
I timed it to 35 thinking that 35 would be the total. I know that's no way to run a car though, always at 35 BTDC. My thinking was that if I removed the spout plug, there would be no feedback to the computer to tell it to advance as I accellerated, so it would hold 35.
I've now retimed it to 10 BTDC with spout removed. Spout is back in now, plug and wire check is next on my list.
So the Astar likes 30 degrees total advance? That's a little less than I'm used to on other cars. It makes sense though, I found today that with the spout in I gain 20 degrees timing over 2500 or so, so I can see the system is working. The operator is challenged.
Old Oct 18, 2006 | 11:56 AM
Aerocook's Avatar
Aerocook
I had a plug that was cracked and causing misfire, I disconnected ignition wires one at a time till I found the one that didnt cause the misfire to worsen. It was when I pulled that plug to insect that I discovered the porcelain was cracked.
Old Oct 18, 2006 | 06:49 PM
250K AS's Avatar
250K AS
I've fixed it. In one swoop I did the rotor, cap, plugs, and wires. Nothing looked too suspicious, plugs looked a little gapped out...electrodes worn down but I didn't measure them. Thanks for the help!
macubus
2004 - 2008 F150
33
Dec 3, 2016 01:57 PM
ULpilot
Jul 13, 2015 10:48 AM
E350Hawaii
1978 - 1996 Big Bronco
Jun 16, 2015 11:54 AM
Macrobb
Jul 29, 2014 06:20 PM
Rubenk
31
Sep 1, 2010 07:32 PM
