Sponsored by: Real Truck
Lift????
Old Oct 16, 2006 | 10:59 AM
02F250XLT's Avatar
02F250XLT
Exclamation Lift????
I am planning on lifting my 250 but i dont know what is the best way to go for the best value... sould i just do blocks, new springs, add a leafs??? or would a body lift do the trick??? whats the best way to go for the best price?? Looking to spend about $400 and i want like 4 to 6 inches thanks
Old Oct 16, 2006 | 12:59 PM
Autobahn F-250 Lariat's Avatar
I don't believe you'll find much for 400 bucks in the 4" - 6" range
Old Oct 16, 2006 | 01:05 PM
highboy390fe's Avatar
highboy390fe
Your not going to get anything of high quality the only thing i would say is this
http://cgi.ebay.com/ebaymotors/ford-...36236011QQrdZ1
I dont know if anyone else has used these or not but im not sure if there anygood and i probably wouldnt buy them but thats just me.
Old Oct 16, 2006 | 01:07 PM
chuck641's Avatar
chuck641
probably the cheapest 4" lift would be pro-comp. it comes with new front springs and add-a-leafs and blocks for the back, along with everything else you will need to complete the swap. I think it runs around 750 bucks. you don't want to use blocks up front, I wouldn't recommend a body lift at all.
Old Oct 16, 2006 | 01:08 PM
you can try this guys not sure of their reputation
http://nixonperformance.com/nixonper...20products.htm
Old Oct 16, 2006 | 02:21 PM
Pocket's Avatar
Pocket
A cheap lift will leave you regretting your decision and money spent.
Old Dec 30, 2006 | 12:54 AM
shellshock's Avatar
shellshock
Pocket your pics are down.
Old Dec 30, 2006 | 02:01 AM
thedaddycat's Avatar
thedaddycat
I don't know about lifting the whole truck, but I'm getting some add-a-leaf springs made to lift the front of my '03 F-350 1.5" and add 1200# capacity(on top of the 4800# stock spring set-up) because I'm getting a snow plow. I didn't want to go with a 2.5" leveling kit which only adds a few hundred pounds capacity. I did want the capacity brought up to the 6000# of the OEM plow prep package but with a little added lift, in part because I'm going with 285/75R16E Terra Grapplers which are a step up from the stock 265/75R16E tires. That's why I went with 1.5" of lift, but could have gone from almost none to a max of about 2.5". Since these springs are being custom made for me by FTE member KansasJoe I could pick how much lift I was getting. You might consider pricing how much it would cost to have a spring shop make you what you want...
Old Dec 30, 2006 | 09:13 AM
Pocket's Avatar
Pocket
Yeah, I'm using a free host and I went WAAYYYYYY over the quota for monthly traffic. It should be back up in a couple of days. When I get some time, I'm moving everything to a new server. I plan on adding some video clips of next season's drag racing events, and maybe some offroading on the Colorado Jeep trails.
Old Dec 30, 2006 | 09:29 AM
cc322's Avatar
cc322
Dont be cheap you get what you pay for, with that said go dr kit imo
Old Dec 30, 2006 | 11:34 AM
oldkountryboy's Avatar
oldkountryboy
if you have a gasser and the most you want to spend is 400 then a body lift is your best bet
if you have a diesel the body lift would be difficult
the hangers from nixon i have heard are pretty good but you will need more than just the hangers to do it all right
Old Dec 30, 2006 | 02:34 PM
BFR250SD's Avatar
BFR250SD
Most leveling kits are in that price range, but....
You have a 250 right? You'll have to kinda piece it, but here is an option.
Get the 4" blocks, shims, and u-bolts for a 350 and use that for the back.
Get a 2.5" to 3" leveling kit for the front.
That's effectively gonna raise the rear 2" and the front 3", so the truck will be almost level, but not quite.
Get a set of 1" longer shackles (or hangers preferably) for the front and you'll have a level truck that should effectively give you 4" of lift.
Now shocks? You're gonna need new shocks if you are going more than 2" up, so keep in mind that is gonna raise your costs up.
Any more than that and yoiu are gonna want a well put together kit.
You'll get what you pay for.
Old Dec 31, 2006 | 12:10 AM
Beerstalker's Avatar
Beerstalker
Anyone know what the normal pricing for the f-350 rear blocks and U-bolts would be?
I think I've bugged Ed enough lately so I figured I'd just ask in here.
Old Dec 31, 2006 | 12:15 AM
shellshock's Avatar
shellshock
So let me get this straight... If someone went up 2" all around they wouldnt have to change anything and it would stay stock handellingand no need for an alignment?
whats the best way to go about doing this? Ive got a 06 250 super d.
Old Dec 31, 2006 | 07:45 AM
BFR250SD's Avatar
BFR250SD
Alignment is always a good thing to do but....
The only thing that you might have to do is recenter your steering wheel. As soon as you raise the front, it changes the angle on the on your steering linkage and throws the steering wheel off.
Real easy, there is an adjuster on the drag link. Just turn it and tighten it back down when your steering wheel is strait.
As long as you only go 2", you'll be okay. You're still well within the normal range of the suspension. The 250's and 350's use the same shocks, even with the slightly different heights.
