Windows too?
Old Oct 16, 2006 | 09:22 AM
X-70STANG-F150's Avatar
X-70STANG-F150
Windows too?
I've read the posts about the door lock regulators and am definitely experiencing that in 2 out of 5 doors. But my windows seem weak and slow too? Do the window regulators have "known" problems also? I've tried searching the forum but only find info on the locks.
Old Oct 16, 2006 | 11:16 AM
kids_ride's Avatar
kids_ride
Are you referring to the front and the slow down in the down movement. I have that on one window, I was instructed to lube the tracks.. I tried it, made a mess and not that effective.. I am going to try to remove the interior panel and lube it that way.
Old Oct 16, 2006 | 11:43 AM
X-70STANG-F150
they all seem slow to me. the fronts worse then the back, especially the drivers window. It seems to be getting worse, I had to help it down the other day. I didn't try going back and forth on the rocker switch to see if it would fade out like the locks do. I'll try that in a little while.
Old Oct 16, 2006 | 01:55 PM
MarkMoore's Avatar
MarkMoore
The window motors are pretty well built and last a good long time (not saying that they won't fail), but my first guess would be that it needs a good cleaning and some fresh lube. When it is going down, is there any noise? Squeeking or Grinding?
Old Oct 16, 2006 | 02:58 PM
eatfish's Avatar
eatfish
Use a dry lubricant like teflon if you do lube the tracks. Petrolium lubricants can cause the material in the tracks to swell and make the problem even worse.
Old Oct 16, 2006 | 03:09 PM
X-70STANG-F150
nope, no noise. I have to get behind the door panel to get to the lock motors anyway, so I'll try to lube the tracks then.
Old Oct 18, 2006 | 09:25 AM
Downriver Thunder's Avatar
Downriver Thunder
My driver's door window got sluggish. Took it into the shop to replace the window motor and didn't cost a dime. All it needed was the tracks lubed.
BigRobK
Jun 25, 2013 10:34 PM
SpeedRebel09
Jan 23, 2013 09:11 PM
whatthencuz
Mar 24, 2010 09:16 AM
ty20404
Jun 24, 2008 05:26 AM
mavman
May 16, 2003 11:25 AM
