engine change
Old Oct 15, 2006 | 08:27 PM
ford360's Avatar
ford360
engine change
i was wondering i have an 1975 ford f100 with an 360 in it can i change to an 352 with out changing any thing.
Old Oct 15, 2006 | 09:30 PM
Dustin1690's Avatar
Dustin1690
Im not 100% sure but i dont think so i could be wrong but they didnt make 352's then maybe someone else can chime in im guessing you will have to change somethings i dont think its direct bolt up
Old Oct 15, 2006 | 09:46 PM
FordBoypete's Avatar
FordBoypete
Thumbs up
Welcome to FTEs 73-79 Forum FORD360 ,
360 CID V8 is an FE series or Family Engine. With FE series engines, where one fits they all fit as far as mounts, exhausts, bellhousing bolt patterns & most everything else goes. Since 352 is also an FE Series engine, the answer is yes.
They're virtually the same engine in that respect. You can direct bolt in and/or replace your 360 FE with a 352 FE drop in & hook it up.
You can also use a 332, another 360, a 390, a 401, 406, 407, 410 427 or 428 version of the FE engine.
but you can't use an FT or other series/ family without changing stuff to do it.
FBp
Old Oct 16, 2006 | 12:28 AM
hatemakings/n's Avatar
hatemakings/n
I believe there was a few years where the heads had a different number of exhaust manifold bolts. Something like 8 bolts on older years, pre 66 ? , and 14 bolts after that year. I can't recall this late at night and the better half is sleeping next to the stack of info. Don't want to wake her. I know I was looking at parts for my 67 FE in a restoration catalog and it lists different bolt partern for the older FE exhaust manifold. It might not have been model years but rather engine size that had the odd number of bolts. Someone with more info on the older FE's will chime in.
Why swap to a smaller motor? Most people want to go from 360 to 390, not the other way. 352, 360, 390 are the same block with different internals.
Old Oct 16, 2006 | 01:10 AM
Mil1ion's Avatar
Mil1ion
The 352 Truck engines of the late 60's would slide right in
What transmission are you dealing with ?
1956in1956
Sep 14, 2013 11:51 AM
67ranger
15
Nov 24, 2009 08:40 AM
travisg96
Engine Swaps
May 21, 2008 04:22 PM
ford360
Oct 16, 2006 07:46 PM
