gauge install
Old Oct 12, 2006 | 11:36 PM
repou's Avatar
repou
gauge install
How difficult and whats involved in installing egt and boost gauges.
Old Oct 12, 2006 | 11:49 PM
shenders99's Avatar
shenders99
How To
Medium - Tapping, Drilling, Splicing, Running, Painting, and a Little Blood.
It is not that big of a deal. I bought mine from DieselManor.com and they come with great step by step instructions.
Old Oct 13, 2006 | 12:03 AM
ponch37300's Avatar
ponch37300
It is a little intemidating at first but once you jump in it is real easy. EGT you can either drill and tap or use the clamp style probe. Boost is just putting a tee in your map sensor line and running the new line to the gauge. You can buy them wired up so all you have to do is install the probes and get power to the gauges.
Old Oct 13, 2006 | 12:30 AM
repou's Avatar
repou
Thanks. Any brand seem to be better than others?
Old Oct 13, 2006 | 01:06 AM
ponch37300's Avatar
ponch37300
I have the isspro gauges. When i bought mine most people seemed to think that they match the factory gauges good and i would agree. Haven't had any problems with them at all and they look great
Old Oct 13, 2006 | 06:29 AM
hookd's Avatar
hookd
If your going for cheap my brother in law bought these and they work great
http://cgi.ebay.com/ebaymotors/99-06-SUPERDUTY-GAUGE-POD-BOOST-EXHAUST-TRANS-TEMP_W0QQcmdZViewItemQQcategoryZ43952QQihZ015QQite mZ250037835642QQrdZ1QQsspagenameZWDVW
Half the price of anybody else I found on the net, good instructions, and easy install
Old Oct 13, 2006 | 10:20 AM
shenders99's Avatar
shenders99
Gauges
I got ISSPro's and love them. The Pyro is marked with yellow and red to help you see where you're at.
Dieselmanor.com has a deal for everything you for need for a three gauge set up for $300 delivered. Only thing extra I needed was paint.
Old Oct 13, 2006 | 03:26 PM
redfire42's Avatar
redfire42
How would you drill and tap for the Pyro senser? wouldn't that put metel flakes in the manafold? Didn't think that would be good to have metel flakes flying though a spinning turbo, but I don't know so thats why I'm here.
Old Oct 13, 2006 | 03:39 PM
bigtorque's Avatar
bigtorque
i dont believe a couple of shavings flowing through the hot side of your turbo will do much if anything. when i dirlled mine. seems that most the shavings fell on me.
im sure something went into the mani.
Old Oct 13, 2006 | 09:05 PM
MikeSDK's Avatar
MikeSDK
As far as flakes in the manifold are concerned, keep coating your drill bit with grease. The flakes will tend to attach themselves to the grease. That being said, after several progressively larger bits coated with grease, after I got to the desired diameter, I spent several minutes with my shop vac trying to get any remainders out of the manifold.
I've had no issues...
Old Oct 13, 2006 | 11:33 PM
05f250fx4's Avatar
05f250fx4
where do you run the wires if you have a manual and your clutch is occupying the hole that people with autos use?
Old Oct 14, 2006 | 01:24 AM
aklim's Avatar
aklim
You can drill the manifold with the engine running and that will blow out whatever chips you have created.
Old Oct 14, 2006 | 12:16 PM
Muktown's Avatar
Muktown
check out this thread for drilling and tapping the manifold
https://www.ford-trucks.com/forums/4...t+pyro+install
Old Oct 14, 2006 | 06:49 PM
shenders99's Avatar
shenders99
Drill with the engine running and use 10-20 drill bits. Start with the smallest and work your way up. Get a small magnet and stick it in the hole every little bit. This worked fine with me. Anything that did not get caught would blow through the turbo before the turbo started and wouldn't hurt anything.
Others here would say the only way to do it it to remove the turbo, then the manifold and do on the bench.
Let us know how it works.
Old Oct 14, 2006 | 06:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Man, don't make me go out and check the firewall for a suitable grommet that you could piggyback for the install. Just have a look. I'll bet there's several spots. If not, simple drill bit and $1.00 grommet from AZ install. Don't make it hard fellas, and don't be intimidated by these trucks. They really aren't that bad to work on. Get in there. Git-er-done.
