gauge install
Old 10-12-2006, 11:36 PM
repou's Avatar
repou
repou is offline
gauge install
How difficult and whats involved in installing egt and boost gauges.
Old 10-12-2006, 11:49 PM
shenders99's Avatar
shenders99
shenders99 is offline
How To
Medium - Tapping, Drilling, Splicing, Running, Painting, and a Little Blood.
It is not that big of a deal. I bought mine from DieselManor.com and they come with great step by step instructions.
Old 10-13-2006, 12:03 AM
ponch37300's Avatar
ponch37300
ponch37300 is offline
It is a little intemidating at first but once you jump in it is real easy. EGT you can either drill and tap or use the clamp style probe. Boost is just putting a tee in your map sensor line and running the new line to the gauge. You can buy them wired up so all you have to do is install the probes and get power to the gauges.
Old 10-13-2006, 12:30 AM
repou's Avatar
repou
repou is offline
Thanks. Any brand seem to be better than others?
Old 10-13-2006, 01:06 AM
ponch37300's Avatar
ponch37300
I have the isspro gauges. When i bought mine most people seemed to think that they match the factory gauges good and i would agree. Haven't had any problems with them at all and they look great
Old 10-13-2006, 06:29 AM
hookd's Avatar
hookd
hookd is offline
If your going for cheap my brother in law bought these and they work great
http://cgi.ebay.com/ebaymotors/99-06-SUPERDUTY-GAUGE-POD-BOOST-EXHAUST-TRANS-TEMP_W0QQcmdZViewItemQQcategoryZ43952QQihZ015QQite mZ250037835642QQrdZ1QQsspagenameZWDVW
Half the price of anybody else I found on the net, good instructions, and easy install
Old 10-13-2006, 10:20 AM
shenders99's Avatar
shenders99
Gauges
I got ISSPro's and love them. The Pyro is marked with yellow and red to help you see where you're at.
Dieselmanor.com has a deal for everything you for need for a three gauge set up for $300 delivered. Only thing extra I needed was paint.
Old 10-13-2006, 03:26 PM
redfire42's Avatar
redfire42
redfire42 is offline
How would you drill and tap for the Pyro senser? wouldn't that put metel flakes in the manafold? Didn't think that would be good to have metel flakes flying though a spinning turbo, but I don't know so thats why I'm here.
Old 10-13-2006, 03:39 PM
bigtorque's Avatar
bigtorque
bigtorque is offline
i dont believe a couple of shavings flowing through the hot side of your turbo will do much if anything. when i dirlled mine. seems that most the shavings fell on me.
im sure something went into the mani.
Old 10-13-2006, 09:05 PM
MikeSDK's Avatar
MikeSDK
MikeSDK is offline
As far as flakes in the manifold are concerned, keep coating your drill bit with grease. The flakes will tend to attach themselves to the grease. That being said, after several progressively larger bits coated with grease, after I got to the desired diameter, I spent several minutes with my shop vac trying to get any remainders out of the manifold.
I've had no issues...
Old 10-13-2006, 11:33 PM
05f250fx4's Avatar
05f250fx4
05f250fx4 is offline
where do you run the wires if you have a manual and your clutch is occupying the hole that people with autos use?
Old 10-14-2006, 01:24 AM
aklim's Avatar
aklim
aklim is offline
You can drill the manifold with the engine running and that will blow out whatever chips you have created.
Old 10-14-2006, 12:16 PM
Muktown's Avatar
Muktown
Muktown is offline
check out this thread for drilling and tapping the manifold
https://www.ford-trucks.com/forums/4...t+pyro+install
Old 10-14-2006, 06:49 PM
shenders99's Avatar
shenders99
Drill with the engine running and use 10-20 drill bits. Start with the smallest and work your way up. Get a small magnet and stick it in the hole every little bit. This worked fine with me. Anything that did not get caught would blow through the turbo before the turbo started and wouldn't hurt anything.
Others here would say the only way to do it it to remove the turbo, then the manifold and do on the bench.
Let us know how it works.
Old 10-14-2006, 06:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Man, don't make me go out and check the firewall for a suitable grommet that you could piggyback for the install. Just have a look. I'll bet there's several spots. If not, simple drill bit and $1.00 grommet from AZ install. Don't make it hard fellas, and don't be intimidated by these trucks. They really aren't that bad to work on. Get in there. Git-er-done.
Quick Reply: gauge install
