when did the 460 externally balanced?
Old Oct 12, 2006 | 07:01 PM
scottie2hottie's Avatar
scottie2hottie
my motor is a 78' cast.....not sure where the motor came from, it was in a 76 pickup i have.
Old Oct 12, 2006 | 07:33 PM
Ford79's Avatar
Ford79
External balance was 79 and newer I believe. You can easily identify an external balance motor by looking at the spacer behind the balancer: smooth, round spacer = internal balanced; hatchet spacer = external balanced.
Old Oct 13, 2006 | 01:10 AM
monsterbaby's Avatar
monsterbaby
Scottie, how do you know it's a 78 casting? is that what the emission tag says or are you seeing a 78 casting number? Mike is correct 79 is when they did the switch but some casting numbers look like D8TE but that number doesn't exist is why I was asking.
Old Oct 13, 2006 | 05:55 AM
scottie2hottie
i was going off the tag on the valve cover is there a better way to find out. Where are date codes on these blocks?
Old Oct 13, 2006 | 07:14 AM
70blue's Avatar
70blue
Block casting number should be right above your starter.
Old Nov 16, 2006 | 10:45 PM
stormy_husky's Avatar
stormy_husky
i have seen 460 lima motors in the John Deere chassis MH's with steel cranks. twice infact. threw me for a curve. but so did that EFI f700 with a carb adaptor and motocraft-holley 4180..
Old Nov 17, 2006 | 12:57 AM
monsterbaby
Stormy, you might want to look at those motors again, they were 429s not 460s, and the 429 truck motors did have steel cranks. The 460s never had a steel crank from ford.
Old Nov 17, 2006 | 05:20 AM
RTM's Avatar
RTM
Aren't those truck 429 motor cranks different than a car 429? I believe the crank snout is longer and has a larger dia.
Old Nov 17, 2006 | 02:29 PM
monsterbaby
yes they are bigger diameter snout, and the dampener is a lot larger too. the main and rod journals are the same diameter though, and the snout can be turned down to passenger car size, but with the new forged cranks coming onto the market the real question is why spend the money to have it machined.
spdcat72
Mar 12, 2016 04:03 PM
Ole' gray
Feb 14, 2012 07:56 PM
Fords_12345
Jun 4, 2005 10:32 PM
lvstang
Modular V8 (4.6L, 5.4L)
Mar 16, 2002 07:17 PM
buzzard
Mar 7, 2001 08:29 PM
