leaky intakes
Old Nov 17, 2006 | 10:41 PM
exploderjoe's Avatar
exploderjoe
leaky intakes
I have recently purchase 2 fords a 78 with a 400(soon to be resold) and a 85 with a 460.
They both have a unacceptable idle and I started searching for vacuum leaks and found both have leaks where the intake mounts to the heads.
Is this a common problem?, Is there a prefered intake gasket set? and while I am at it should I upgrade the intake on the 460? I have been looking at the performer for the 460, the truck will be mainly used for towing
Old Nov 17, 2006 | 10:50 PM
85e150's Avatar
85e150
Common. Folks '77 LTD had a leaker in about '80-81. Just a new set of gaskets and no more troubles. As for the manifold, search the threads. Some good ones out there if you want to upgrade...
