Catalytic converter
Old Oct 12, 2006 | 04:52 PM
Fifty4F100's Avatar
Fifty4F100
Catalytic converter
This is a question I'm sure I'll get some heat on. Has anyone with a computer controlled vehicle removed the catalytic converter all together? Will the computer run the engine without one? I do NOT have emissions testing where I live and I have a clogged converter.
Old Oct 12, 2006 | 05:53 PM
biggreentank's Avatar
biggreentank
If there isn't an O2 sensor behind or in the cat you can remove it.
Old Oct 12, 2006 | 07:30 PM
Fifty4F100's Avatar
Fifty4F100
What about the gas vapor return line? Can it be plugged?
Old Oct 12, 2006 | 08:16 PM
Josh88Ford's Avatar
Josh88Ford
I took mine off to do true duals. The o2 sensor is still there, but otherwise its just straight piping//
Old Oct 12, 2006 | 10:11 PM
biggreentank
Yes it CAN be plugged but you want your tank to breathe don't you??
Old Oct 13, 2006 | 09:06 AM
Fifty4F100's Avatar
Fifty4F100
Gas vapor line is probably not the correct term. I'm talking about the return line that comes off of the converter and I think runs back into the fuel system somehow.
Old Oct 13, 2006 | 09:12 AM
Kemicalburns's Avatar
Kemicalburns
that tube runs from the converter to a valve behind the heads. fromt here it goes to a crossover pipe an connects to either head to bring unburnt vapors back into the head to be reburned. you would want to remove this cross over as well and install plugs into the back of the heads. i will say its a royal pain with the heads on the motor but can be done from what i hear.
gblaz123
Aug 8, 2012 07:46 AM
mcghan
May 25, 2012 07:22 PM
89-96ford
Jun 1, 2010 05:21 AM
lukaspriest
May 24, 2010 03:06 PM
boogity24
General Automotive Discussion
Jun 19, 2004 06:45 PM
