62 F100 STEERING REPLACEMENT
Old Jun 2, 1999 | 08:02 PM
JAKES71's Avatar
JAKES71
I have a 62 f100 stepside and it has a one piece column and gearbox i adjusted it out all the way and still has play what column and gear box can i put into this for a replacement im trying to find a good year that would bolt up that i could find at a salvage yard im low on $ so i have to improvise. I know borgeson is the right way to go but i need a cheap fix thanks all.
Old Jun 3, 1999 | 10:45 PM
docfestus's Avatar
docfestus
Old Dec 14, 2011 | 11:03 AM
waltharper's Avatar
waltharper
Well mine is working on my "62" but I am toying with putting in Power Steering. Wonder how hard it is to change to PS?
At least mine is shifter is on the floor
Old Dec 14, 2011 | 11:49 AM
garbz2's Avatar
garbz2
You adjusted what out all the way? There is no adjustments for a ford integral box only pre-loads, and this has to be done with special tools and procedures.
There is no direct replacement for the 61 to 64 ford integral box and shaft unit.
A rebuilt one will run in the range of 350 to 500 dead Washington's.
There is no cheep fix for steering or improvisation as it is a life safety issue.
Garbz
Old Dec 14, 2011 | 12:23 PM
garbz2's Avatar
garbz2
No one makes a kit to provide power steering for the 61 to 64 straight axle slicks. Rob at No Limit engineering was doing something with adding a rack and pinion to 61 to 64s but i have not heard if he is offering them as kits anymore.
No one makes aftermarket brackets to mount a power steering pump to 223 or 262 engines.
It can be done if you have fabrication skills and tools. A mid 80s Toyota 4x4 PS steering box has a very similar size and requires a custom 90 degree bracket to mount it to the inside of the frame rail in the stock location. These can be run with a ford or GM pump, i would recommend a small GM metric unit but again a custom bracket will need to be fabricated and sheaves located to provide drive at the crankshaft. (again a rare item)
The steering arm also needs modifications by a really competent welder as that the pittman arm needs to be a hybrid of the toy end and the ford end.
The steering column will also need to be modified to accept a lower bearing and retainer and a new shaft sourced or cut off from your existing box and reused.
Ford has PS on some 223s but really rare. However the pump they used is not compatible with the toy box as they require a modern bypass type pump. There was a ram type PS offered as a dealer add on but i have never seen one for a 223 only for 292s
I did a conversion to a toy box on a 63 F100 Uni in 2005. I fabricated a new angle mount, Modified the pittman arm and adapted the Toyota hose ends to gm as the truck had a small block chevy so brackets were easy. The customer already had a universal IDIDIT column. I fabbed up a lower mount and and made the connection with a borgeson universal.
61 to 64 are hard to provide PS for buy the 65 66 truck with the new twin I are simple even a geico caveman can do it as there is all factory components to do it.
Garbz
Old Dec 14, 2011 | 01:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 62 F100 Flareside and it has a one piece column and gearbox. I adjusted it out all the way and still has play. I need a cheap fix.
You want a cheap fix? Buy the following, install, then use steering gear grease instead of gear lube.
These parts will tighten up the gearbox, how much so, I cannot say. It depends on how worn the expensive, hard to find worm & shaft, sector shaft are.
These parts should be no more than $150.00 total. maybe less. These are the same parts that peeps install in a "rebuilt" gearbox that costs 100's of buckaroo's more.
1961/64 F100/250 2WD
2) C2AZ-3552-A .. Worm & Shaft Bearing Cup / Obsolete
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-77-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 411 = 800-476-9653.
2) C2AZ-3571-A .. Worm & Shaft Bearing / Obsolete
CARPENTER has 2.
ANTIQUE AUTO SUPPLY in Arlington TX has 2 = 817-275-2381.
HASELDEN BROTHERS in Hemingway SC has 3 = 843-558-2134.
1) B8A-3576-A .. Sector Shaft Bushing / Obsolete
HASELDEN BROTHERS has 1.
ANTIQUE AUTO SUPPLY has 1.
TISON MOTOR CO. in Estill SC has 1 = 803-625-2551.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
1) C3AZ-3581-A .. Housing Gasket / Obsolete
PARTS INTERNATIONAL has 33.
CARPENTER has 46.
GREEN SALES CO. in Cincinnati OH has 447 = 800-543-4959.
1) C3AZ-3591-A .. Sector Shaft Seal / Obsolete
GREEN SALES has 7.
CARPENTER has 30.
Old Jan 3, 2012 | 06:58 PM
Chad63F250's Avatar
Chad63F250
Garbz2,
I'm doing a lot of work on my 1963 4x4 F250. Do you have a site you recommend for purchasing a rebuild kit or a rebuilt manual steering box? I've been talking with Bill W he sent me a link to black birds for a disc break conversion kit, but it does not have a master cylinder or booster. He just said he used a mid 70s do you know if a 76 will bolt right up to my 63? Thanks for the help.
Old Jan 3, 2012 | 11:47 PM
garbz2's Avatar
garbz2
Originally Posted by Chad63F250
Garbz2,
Chad,
The 4x4 mounting plate needs to be modified to accept a later ford booster. There are two counter sunk 5/16 machine screws facing out to accept the single pot MS. The booster needs to be mounted to this plate by drilling and adding four counter sunk bolts or drilled and welded studs and still clear the four bolts that sandwich the firewall and pedal brackets. . Just center the lever for the booster in the middle of the existing hole for the old single pot.
I use lever type boosters from a 78 as they raise the booster up and away from valve covers. I also scrounge up an eccentric bolt from the same year. Once it is mounted mark the lever where you want it and drill a new 9/16th hole for the bolts shank and bushing. you will have to search the yards as the lever unit does not come with rebuild boosters.
Add any ford F250 master for power drum. 67 to 72's dump out the drivers side for the brake lines. 73 to 79 dump out the passenger side of the master.
Garbz
Old Jan 4, 2012 | 04:31 AM
Chad63F250's Avatar
Chad63F250
Garbz,
Hey thanks for the detailed response! Do you have any suggestions on where to pick up a new steering box? Right now I'm looking at getting a rebuilt one from LMC, but I'm thinking there is probably a better deal out there.
Thanks,
Chad
Old Jan 4, 2012 | 10:26 AM
garbz2's Avatar
garbz2
Garbz,
Thanks,
Chad
LMC only gets them from the same place you can and marks them up 200 bucks.
Here is a thread that mentions re-builders in Virginia. Steering Box Rebuild
Here is a good shop in Washington. Red-Head Steering Gears
Here is Bench works out of Scottsdale AZ. benchworks steering
Look in your yellow pages and see if there are any other near you. The last place i would purchase a box is LMC.
Garbz
SyngleA
Oct 27, 2016 09:04 AM
T_Cooksey88
Mar 17, 2016 11:23 AM
Cazman1955
Feb 1, 2016 05:12 PM
DuallyF350
May 12, 2015 08:12 PM
jethrob
Sep 18, 1999 09:04 AM
