Keypad code on door.
Old Oct 10, 2006 | 07:15 PM
jmdetermann's Avatar
jmdetermann
I purchased a used 2001 Ford Eplorer Sport Trac sometime ago.
I have never known the code to the outside door keypad. I know usually it's on the card in the owners manual. In this case It didn't come with one.
I know there is somewhere in the vehicle in which the keypad code is on a sticker. I jsut don't know where to find it.
Does anyone know where to find the keypad code location on a 2001 sport trac?
Thanks in advance.
-Jon
Old Oct 10, 2006 | 08:48 PM
sport_trac_drew's Avatar
sport_trac_drew
Do you have a job 1 or job 2? If it is a Job 1, it is behind the rear panel behind the rear seats. Job 2 and newer all you got to do is remove the the passenger air bag, you can access it by opening up your glove box and looking up there 2 brass looking screws unscrew them, slide the airbag out then unscrew the plastic cover for the computer and on top of that is your 5 digit code. Good luck finding it. Check out www.mysporttrac.com for some good info also. Just like this site, there is alot of good info and great people that will help you out.
Andrew
Old Oct 10, 2006 | 09:56 PM
LABulldog's Avatar
LABulldog
Go to www.mysporttrac.com and do a search and there is a detailed account on where to look for code.
PS If you ST is a job 2, its behind the passenger air bag!
Jay
Old Oct 10, 2006 | 10:15 PM
LABulldog's Avatar
LABulldog
Is the ST a job 1 or job 2? What is the date of manufacture? Should be on the door sticker. The job number will make a difference in the location.
Old Oct 10, 2006 | 11:11 PM
sport_trac_drew
if its a job 1 the keypad code should be somewhere in the cargo bin behind the rear seat. If its a job 2, it should be in the glove box near the airbag. I think there is a project on finding this on www.mysporttrac.com . Good luck finding it.
Andrew
Old Oct 10, 2006 | 11:39 PM
buckets's Avatar
buckets
I was told that if you were to bring your truck to a ford dealer and show them the V.I.N. they could give you a generic code to give you the capability to program your own. Good Luck!
Barry
Old Oct 11, 2006 | 08:35 AM
sport_trac_drew
sorry for all the post, I was having trouble posting last night at work.
Old Oct 13, 2006 | 06:59 PM
jmdetermann
How do I know which "Job" I have? I don't see it behind the seats where the jack is.
So i'm guessing I have the other.
-Jon
Old Oct 15, 2006 | 09:40 PM
restoringmy46's Avatar
restoringmy46
I bought a 02 Mercury Mountaineer and all I did was I took it to the ford dealer and they put it on the computer and told me what it was in 2 mins. Didn't cost me nothing. That is the easiest way to do it.
Old Nov 5, 2006 | 05:01 PM
jmdetermann
I attmepted the dealer. They told me 85 bucks to get the code.
-Jon
Old Nov 7, 2006 | 08:02 AM
spudtang92's Avatar
spudtang92
Id check these four places: inside the glove compartment; on the drivers door jamb area; rear drivers side wheel weld area; on top of the electrical connectors in the rear drivers wheel weld area.
Mine was located on the rear drivers side wheel weld and was only visible with a mirror and a flashlight. You're looking for the digits on top of a sticker. Once you get the #s, write them down on a pc of masking tape and put the tape in your glove compartment.
Good luck!!
Old Nov 8, 2006 | 07:55 PM
russ&irene's Avatar
russ&irene
Thumbs up
After you get the code, print it inside the gas filler door. That way when you lock your keys inside, open the gas door read the code and you can get in.
russ
Old Dec 20, 2006 | 08:45 PM
Redbob's Avatar
Redbob
Mine was located on the rear drivers side wheel weld and was only visible with a mirror and a flashlight. !!
What. pray tell, is a "Wheel weld?
aletheuo
May 31, 2012 10:19 PM
jdhudall
1997 - 2003 F150
Dec 28, 2007 08:11 PM
valeyra
Feb 15, 2007 06:47 PM
02PSDCREW
Oct 18, 2005 07:54 PM
