AOD or C6 or ?
This truck currently has an FMX transmission with a 2000 stall.
I have been given an AOD transmission out of a '89 Mustang that had a 5.0 in it.
Will this work on my motor? If so can anyone tell me what all I'll need to do to make this change?
........or would a C6 or maybe C4 be a better choice?
Any and all suggestions would be greatly appreciated!
The AOD will work for light duty useage, but don't expect to be hauling heavy loads.
It's dead On,especially about difference in Static Balance criteria @ year of engine and the critical nature of the TVR Cable being right.
Be sure the torque converter housing is the right on for the engine also. I have seen them with additional windsor wieghts on them. . . . I don't know the listing on that, but someone may have it or have the explanation of it here. . . . If not get it from the A/T forum here at FTE.
I would add if you're going to "push the envelope" also use an atmosphere/ air cooler for ATF. The cooler ATF returns the better it runs & longer it lasts.
FBp
Jason
It doesn't break & I doubt any street 5.0L running a carb will generate anywhere near the torque of a built 460 at the 1/4 track.
The weak part of AOD is the Planetaries. If he races in OD he deserves to break it. As far as going down the road, the addition of an air cooler will keep the planetaries, aka OD section of the tranny comfortable. He should not have failure problems.
On the otherhand, C-6 has about 22% loss coefficient whereas smaller lighter built- easier running AOD has an 11% or 12% loss coefficient in the non OD range & 17% +/- in OD (at higher ground speeds of course) where the inertial loading is virtually gone.
What do you base your failure prediction on ?
If it was an early 1st generation AOD I might agree, but after 86 FoMoCo introduced their Generation 2 AOD (which is what he wants to use) he should be good to go.
FBp
Go here for beef up goodies for the AOD. The TV cable thing is a BIG DEAL on the AOD so make sure it's right.
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/Products/Ford/ford_aod.asp
Happy motoring!
Jason
An earlier AOD would be a better choice because it uses a T.V. rod instead of a cable, which would be easier to adapt to your application. You may want to look if there's an aftermarket kit (or factoryparts) to convert your cable to the rod.
I decided that the C6 that I put in with my Dana 60 running 3.54's just wasnt cutting it with my choice of tires & distance driving.....
After thinking long & hard about the benefits of O.D.'s I decided to go with a "Dominator Jr." AOD tranny from
www.ford-aod.com
It is rated to 500hp & I will never even come close to that with my mildly built 352.............
The whole package came to $2700.00 with Tranny/Torque Converter/Flex Plate /Adaptor for 352 etc./Starter/Dip stick/Lokar Kickdown Cable (very important as stated in previous posts)/Carb mount/Tranny Cooler........AND $110.00 Credit on Shipping which brought to the shop door shipping to $65.00!
This will give me a .67 final drive on the tranny.........with my 3.54 gearing I should end up around 2.77 final on the rearend.
A vast improvement over running my motor at 3000 to 3500 when flying down the freeway.
Good luck as I am right there with you!
I also have a 85 T-bird Elan with a generation 1 AOD that has 155+K on it, & my wife & daughter drove both these.
I have a friend that has an 03, Brand X, Silverado. He's on his 3rd AOD and coming up on 85K miles, so I guess some have better destiny than others.
Now the 3rd Gen', A4ODE from 95/ 96 up is a bad idea no matter who owns/ drives it.
Performance "re-Mans" that offer warranties stating power tolerance & milage can't be all that bad either. A lot of folks run them & run them Hard. . . .
FBp
There have been millions of Mustangs and Crown Vics with the AOD. They used them on full-sized trucks until around 1992. They aren't as fragile as has been suggested.
..Correction, my C6 is 1:1 with my 3.54 rear end gears...
The A.O.D. is .67 in 4th.....
I know that rear end gearing will not physically change....but....
There was a calculator that I used online,that stated that my rearend would behave like a 2.77 geared rear end in 4th gear.
(It had a listing of all the different O.D. units available & I cant locate it for the life of me).
Which seems a little off I admit considering my RPM's will only drop by aproximately 900 @ 65 mph
Please,
if this incorrect...........put up the formula that gives all the aspects so I can do the math.
Thanks in advance.
From the Gearvendors website.......
I am a little off as this is for a .78 Overdrive......But you get the idea...
Gearvendors
No matter how you slice it, if we are to drive these trucks on a daily basis an O.D. is the way to go. (At least in my case as I want the bulletproof Dana 60 to stay).
