AOD or C6 or ?
Old Feb 12, 2007 | 07:14 PM
  #31
gator1965's Avatar
gator1965
I use a c4 behind my 65's 302 engine, my engine is built similar to yours. I would say the c4 would be an easier swap, and they dont rob as much power as a c6 and are lighter. on the other hand a good aod would be great, as long as you properly adjust the TV (throttle valve) cable, you could also run steeper gears inthe rear an get the same mileage compared to a 3spd. IF you go either aod or c4 i would recomend a shift kit, as it will give your trans more life, because they are bad for 2-3 gear flare up.
here is a good forum for c-4s and others, there are many guys running 11s to mid 10s on a sock c4 with shift kit,stall,manual valvebody.
www.fordmuscle.com look for the trans fourms, lots of good info
onesun1949
Apr 14, 2011 09:19 AM
madrox
Nov 25, 2009 10:18 AM
Milwaukee1979F150
Nov 23, 2009 05:58 PM
Jsbiohazard
15
Mar 13, 2006 01:33 PM
gov2mod
1978 - 1996 Big Bronco
Nov 14, 2005 10:07 AM
