can anyone give me their experienc with the superchips programmer for 2006 6.0L I am thinking of getting on but want to here about them. Also what about the sct tuner. thanks in advance
I drive a 2005 F250 with the 6.0. I have a superchips 1708A and I love it.
It has 3 settings(plus it keeps your stock setting) and the setting are 67hp, 90hp and 99hp I think.
Mine plugs into the CPU port under the dash and takes about 3 minutes to change settings.
The only problem I had was with the latest flash that the dealership did. The programmer did not work so I called Superchips and told them about it and they told me to mail it to them. I got it back 10 days later and all is good again.
hey ABFORD, check out the superchips thread and you can get some good insight on the superchips from when it first came out to present https://www.ford-trucks.com/forums/2...ogramer+thread
I;ve had good luck with my 1805 flashpack but with any custom tune where you increse cylinder pressure these engines tend to blow head gaskets due to lack of cylinder head studs .
