main bearings
Old Nov 5, 2006 | 03:39 PM
  #31
lilpro's Avatar
lilpro
Im going to list all the parts im considering buying. Can you please tell me if all the parts are compatable with each other, if i can use 92 octange, what the compression ratio is, and if anyone has a desktop dyno program to run these parts for me and tell me the results. Thanks
PARTS LIST
  • Scat 4.300 crank
  • BB Chevy Rods 6.8
  • Xtreme 4X4 Hydraulic Flat Tappet Camshaft - .574" Int .580"
  • BB Ford Inverted Dome JE Pistons,
    <table border="1" cellpadding="2" cellspacing="2" width="100%"> <tbody><tr class="specTableTitleBar"> <th>Bore size</th> <th>Stroke</th> <th>Rod</th> <th>Comp/Hgt</th> <th>CR w/74cc</th> <th>CR w/80cc</th> <th>CR w/94cc</th> <th>Dome volume</th> <th>weight</th></tr> <tr class="specTableData"> <td>4.390</td> <td>4.300</td> <td>6.800</td> <td>1.350</td> <td>9.7</td> <td>9.3</td> <td>8.5</td> <td>-39.0cc</td> <td>569</td></tr></tbody> </table>
Thanks
Michael
Old Nov 5, 2006 | 04:00 PM
  #32
monsterbaby's Avatar
monsterbaby
Well the first and formost thing I see is the heads you have linked too ain't gonna work with any of it. Those are C460 heads thats one step above the heads I run on my race engine, they take custom pistons, special intakes, use a Chevy exhaust pattern for the headers and as I recall need atleast a 4.5" bore min and recommend a 4.6" bore.
And on top of that you can't afford the rockers for those heads let alone the rest, plus they aren't ported or even actually really finished for use as cast. The rockers alone will push into the $1400 range all finished setup and ready to run those heads will cost you in the 4-5000 range plus corrosponding parts to make them work.
Old Nov 5, 2006 | 04:03 PM
  #33
lilpro's Avatar
lilpro
What head would you recommed then that will work with all the other parts?
Old Nov 5, 2006 | 04:10 PM
  #34
monsterbaby
something along these lines would work.
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 5, 2006 | 05:06 PM
  #35
lilpro's Avatar
lilpro
IS there anything a little cheaper? About in the $1500 range that would work?
Old Nov 5, 2006 | 06:19 PM
  #36
monsterbaby
Yeah stock heads, those ones you linked too were 995ea bare that means without valves springs or anything. The ones I linked too are a little over $1000ea complete.
well I guess the edelbrock heads are a little cheaper but not much, $899 each.
Old Nov 5, 2006 | 10:12 PM
  #37
Paul Kane's Avatar
Paul Kane
Smile
Originally Posted by monsterbaby
Paul, I agree on an internally balanced engine this should be the case but I do like to have those parts put on after the crank is done to double check those parts I have found on occasion (rare but it does happen) that a dampner and/or flywheel was out of balance..
Ya know, this is a really good point, MB, in that it may also be that if the rotating assy was balanced previously by a lazy shop, then the zero balance parts may have already been drilled into and f'd up in the process of bringing the assy into balance. Defintely a good idea to check everything out...
Paul
Old Nov 6, 2006 | 01:16 AM
  #38
darrin1999's Avatar
darrin1999
but those edelbrock heads have cheaper hardware on them... like single springs, 7 degree retainers and locks, smaller intake valves, and cheaper valve seals. youd be better off with the tfs ones that monsterbaby originally suggested- just be sure to get the proper headers for them
lilpro
Apr 12, 2013 09:56 PM
TODDXDC
Dec 10, 2009 10:09 AM
BAJI26
Jul 6, 2009 03:12 PM
mike2755us
2004 - 2008 F150
Nov 1, 2006 09:55 PM
lowburb
Dec 29, 2001 09:54 AM
