main bearings
Old Oct 8, 2006 | 07:39 PM
lilpro's Avatar
lilpro
main bearings
I plan on going with a 514 setup and i order my crank already but i was wondering what size main bearings i need? I think stock, but am not postive.
Thanks
Michael
Old Oct 8, 2006 | 08:17 PM
greenhighboy's Avatar
greenhighboy
You need to check with who you got the crank from. Some aftermarket cranks have a different radius on the edge of the journals than a stock crank has and requires the use of a bearing such as a Cleveite H series.
Old Oct 8, 2006 | 08:21 PM
bronco521's Avatar
bronco521
if it's a scat you need regular ford mains and big block chevy rods.
Old Oct 8, 2006 | 08:27 PM
lilpro's Avatar
lilpro
Heres the crank i bought click here.
Thanks
Michael
Old Oct 8, 2006 | 10:13 PM
bronco521's Avatar
bronco521
that uses bbc rods and ford mains.you realize with a 4.140 stroke you have to bore the block .080 to get 514.your going to have to make sure the block can go that far.if you had gotten a 4.300 stroke you could get a 514 with a stock bore,521 .030 over.
Old Oct 8, 2006 | 10:28 PM
lilpro's Avatar
lilpro
What about this one?
Old Oct 8, 2006 | 11:11 PM
bronco521's Avatar
bronco521
thats the same one i have.6.800 rods and je dish pistons.mine was internally balanced.
Old Oct 8, 2006 | 11:17 PM
airharley's Avatar
airharley
How about this one?
http://cgi.ebay.com/ebaymotors/513-5...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/crank...spagenameZWD1V
I always check ebay to see what else is out there. Sometimes it's a good deal sometimes not. But it does give you a few more options to look at.
Old Oct 8, 2006 | 11:26 PM
bronco521's Avatar
bronco521
personally i would stick with scat or eagle.do a internet search on hawks cranks and see what people have to say about them, some of it isn't too flattering.
Old Oct 8, 2006 | 11:32 PM
airharley's Avatar
airharley
Your right, most of the comments I read said the cranks weren't the best. Some said the cranks were textured like a cob after you remove the corn. Also a lot of issues with balancing the rotating assembly due to piston/rod clearance or internal alloy differences.
Old Oct 8, 2006 | 11:53 PM
monsterbaby's Avatar
monsterbaby
go with the scat or eagle crank, and run federal mogul 134M bearings (summit part number FEM-134M) it's a competition bearing with the wider radius for most of the stroker cranks, I run them and abuse them without trouble. and for the rod bearings just use the standard size BBC 2.200 rod bearings something like the clevitte P series or H series will work on that crank.
Old Oct 10, 2006 | 10:21 AM
lilpro's Avatar
lilpro
I just ordered the scat crank. NOw im wondering about connecting rods. I think i need 6.700 and 2.200 right? Aslo i was reading and it said 6.700 is minumin, so does that mean i can go with a longer connecting rod? And if so how long before my pistion will be hitting my heads?
Thanks
Michael
Old Oct 10, 2006 | 11:28 AM
bronco521's Avatar
bronco521
you should order a kit.that way you get the right rods and the right pistons.
Old Oct 10, 2006 | 12:07 PM
greenhighboy
Yes. A kit is the way to go about this. You will get a crank,rods, bearings,rings and the correct pistons in the compression ratio that you need. They are usually cheaper than pieceing one together.
Old Oct 10, 2006 | 12:11 PM
monsterbaby
Direct answer to your questions is yes 6.7 is the minimum, I never liked kits personally because you get what someone else thinks you need. You can run the 6.8" rods on that crank and then you have to order a piston that is setup for the stroke rod combo you went with.
