Will this work - exhaust
Old Oct 27, 2006 | 10:18 PM
mgraveman's Avatar
mgraveman
Dual 2.25 - two each of these:
http://store.summitracing.com/partde...5&autoview=sku
This is a stock truck. I will probably do a straight up timing chain, and maybe MAF conversion, but that's it. Not much towing, but almost always loaded, and fairly heavy. No freeway friving, but lots of driving through fields and gravel roads, ect.
Thanks!
Old Oct 28, 2006 | 01:15 AM
Bear 45/70's Avatar
Bear 45/70
Unless you live somewhere that requires the cat for emissions testing, don't use it. They are expensive and an exhaust restriction.
Old Oct 28, 2006 | 02:42 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
Talking
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MPE%2D94005CA&N=7 00+4294923429+4294838974+4294867633+4294891681+429 4788249+4294788248+4294867627+400636+115&autoview= sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MPE%2D11215&N=700 +4294923429+4294922711+400636+4294922710+429489168 1+4294906131+4294788249+4294788248+4294906132+4294 906122+4294906128+4294901611+115&autoview=sku
Thanks!
Those are excellent choices.
Dual cats will help eliminate the exhaust restriction found in the fuelie application. Removing the cat is not only irresponsible but can foul up your computers ability to manage the engine if you have an OBD II vehicle with the O2 sensors before and aft of the convertor.
Properly sized cats only cost 7 to 10 HP in an application like the fuelie 460.
And as a side note all fuelie engines have the straight up timing set installed from the factory.
Adding some additional ignition lead will help power and mileage too.
Scott Johnston
http://reincarnation-automotive.com
Third place finisher "Engine Masters" 2006
Old Oct 28, 2006 | 09:36 PM
mgraveman's Avatar
mgraveman
Scott Johnston
Thank you - will the extra ignition lead cause problems grossing from 7-10k lbs? Where do I go to with it?
I am not too interested in doing something illegal - especially if I can make it legal for $100 or $150.
Any other advice for some better driveability?
Old Nov 4, 2006 | 01:13 PM
darrin1999's Avatar
darrin1999
id say get some decent headers and port match the exhaust to the headers, and port match the intake to the heads... maybe port the exhaust too... that should help alot, and maybe once you get it swapped over to mass air you could throw an rv cam in
Old Nov 4, 2006 | 01:30 PM
The "Mad Porter"
Unlike the early passenger car castings...
the fuelie castings have a pretty darned good exhaust port. It is the intake side that is some what restricted.
Port matching the intake manifold runner exits to the heads is a waste of time because it bell mouths the intake tract at the flange. This cross sectional increase is not good for flow or maintaining velocity. Depending on year a larger intake valve will help more so than anything because the fuelie heads have a 2" intake in the E7TE's and 2.1" in the F3TE's. For grunt the stock heads are pretty good though.
Headers are never a bad thing though.
Regards,
Scotty J. / RHP
http://reincarnation_automotive.com
Old Nov 4, 2006 | 05:11 PM
Brad Johnson's Avatar
Brad Johnson
Before I went throwing cats and other stuff at it, I'd take a loooooong look at some good headers. You'll get a better return on your investment. Then turn it over to Scott and let him have a go at the heads.
Brad
Old Nov 5, 2006 | 04:45 PM
mgraveman's Avatar
mgraveman
Well it needs an exhaust. That's the reason for doing that.
Are headers really worth it? I don't particularly want to spend money on something that - I'm fine with the power level now.
Old Nov 6, 2006 | 08:35 AM
darrin1999's Avatar
darrin1999
if you get headers your mileage may go up a point because the engine wont have to work as hard to get rid of exhaust... and since youre going aftermarket exhaust anyways- you may as well go all the way to the engine and take advantage of a little more power as well
