washer woes
Old Oct 8, 2006 | 02:41 PM
nomadic's Avatar
nomadic
washer woes
I could use a little advice on a washing machine. It will not adgitate at all, the adgitator seems as though it is frozen...It is not like a broken belt, it will just not turn at all....Some sites refer to a broken belt, or a loose belt, or possibly a switch....It is still so pretty, I hate buying a new one if I don't have to.....lol....Help if you can.....Thanks in advance....Nomadic
Old Oct 8, 2006 | 07:06 PM
Zip's Avatar
Zip
No advice but mine is broken as well. Wont spin.
Old Oct 8, 2006 | 08:26 PM
Dialtone's Avatar
Dialtone
My wife's Matag washer / dryer (never go here again) was having some trouble with not spinning properly.
After a while, I noticed that it a was hit or miss problem and figured out it was the timer/switch mechanism.
Bought one at a local appliance parts dealer and it solved the problem nicely, but it was EXPENSIVE. Cost over $90.00 for that cheap bunch of plastic and recycled tin can contacts.
At any rate, for both of you, check out the timer switch. If you are lucky, you can find a wiring diagram online that may help troubleshoot the problem.
P.S. Washers have a transmission that has electric controls off the timer which controls all of the operations in the cycle. Just because you cannot move the agitator by hand doesn,t necessarily mean the transmission is faulty. Ours won't move by hand either.
Did I mention to check out the timer/switch?
Old Oct 8, 2006 | 08:27 PM
TigerDan's Avatar
TigerDan
I would suspect the transmission. Not that I'm an expert on appliance repair but in my experience when the agitator won't move, then it's usually because the transmission has gone bye-bye.
Old Oct 8, 2006 | 11:24 PM
bdjupiter's Avatar
bdjupiter
Is there anything under the washer like black rubber looking material, if so your transmission is probably out and it is cheaper just to go ahead and buy a new one.
Old Oct 8, 2006 | 11:31 PM
sierraben's Avatar
sierraben
Did you feed the squirrel in the cage that turns the agitator?
If it's old, you might want to think about getting a new one.
Ours kinda does the the same thing.
The timer is on it's way out, so the transmission won't engage until the timer is in position.
When it goes, I'll buy a new washer; it's a 39 year old Sears Kenmore.
Old Oct 9, 2006 | 11:56 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
What brand is it???
What model?
Manufacture date?
Does the washing machine run, other than the agitator not turning?
Is there a spot or puddle of oil on the floor, under the machine?
Any black, sooty (or rubbery) residue?
You don't give enough information/description to tell what it could be!
Someone might be tempted to say that the 'Overhead Muffler Bearings' are siezed, or, the 'Wobbling Pin' is loose.
Keith
Old Oct 9, 2006 | 11:57 AM
couleeman's Avatar
couleeman
http://www.repairclinic.com/0070.asp
Try this site. Used it a few times.
First check the timer. If it isn't that, then most likely the repair will cost almost as much as a new washer. Mine did the same thing about a year ago and it was the transmission.
Old Oct 9, 2006 | 02:09 PM
nomadic's Avatar
nomadic
Thanks for the advice gentlemen....I will check under the washer and see if I can find any residue or anything that could have to do with the transmission....The washer is not that old, but it was kind of a cheapie to begin with....Everything works great with the exception of the agitator....I guess I could get the wife to agitate with an old broomstick and save the price of a new one....What do you think? Nomadic
Old Oct 9, 2006 | 05:04 PM
Beast12's Avatar
Beast12
I have a problem with my washing machine. Seems the spin cycle is not working unless I "jump start" it. Here is how I fixed it: https://www.ford-trucks.com/forums/s...6&postcount=38
-Matt
Old Oct 9, 2006 | 05:38 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I have trouble with my washing machine too.
She sleeps late on Saturdays.
Old Oct 10, 2006 | 06:06 AM
00BlueOvalRanger
nomadic:
Again. . . . .
What brand of washing machine is it?
What model?
What is the manufacture date?
The serial # would help, too!
All of this information should be on the machine, on a tag, somewhere near the lid, or just inside the lid.
Without this information, everything will be a guess. A guess won't fix the machine.
Old Oct 10, 2006 | 06:12 AM
06supercrew's Avatar
06supercrew
Check to see if anything is under the agitator ( sock, underwear etc.) that could be binding it. I had that happen once.
Good luck.
mark a.
13
Jul 9, 2011 09:00 AM
dchamberlain
Apr 14, 2011 09:10 AM
cjben
May 6, 2008 06:18 PM
MRKnight
17
Apr 14, 2005 04:19 PM
Chuck 6083
May 25, 2003 03:04 AM
