ENGINE WON'T START....HELP
Old Oct 28, 1999 | 08:46 PM
Joel Mullis
Guest
Posts: n/a
I have just installed a 351M in a 66 F-100. I have a HEI with a MSD ignition. I also installed a new wiring harness from Centech. I turned the motor over and on both sides of the motor between the 2 and 3 pipes of the headers there are sparks. After inspecting the starter to see if it was shorting to the headers, I saw no marks and I had the engine grounded. I tried it again and I guess the starter went out because all it does is click. I'm replacing the starter any ideas on what to check before I turn it over again.
Old Oct 28, 1999 | 09:04 PM
charles_1's Avatar
charles_1
Are you sure that the power wire to the starter isnt grounding somewhere. Mine did the same thing and I found my wire grounding on the frame. I taped up the wire there and moved it and the starter was fine.
Old Oct 29, 1999 | 12:55 PM
Willie's Avatar
Willie
Did you test the starter relay to see it was any good.
Old Oct 31, 1999 | 02:52 PM
Scott's Avatar
Scott
hey ya'll, I seem to be having a problem getting the engine in my truck to start, but however the problem isnt getting it to turn over, it keeps backfiring through the carb (i know timing is off) but when i parked it (before the small engine fire) it was right on 6deg btdc. I also need to know on the dist. cap which is #1. is the firing order
1 5 4 3 2 7 6 ?
HELLLPPP any info Possible please.
Scott
Old Oct 31, 1999 | 02:53 PM
Scott's Avatar
Scott
Sorry I forgot to mention its a 390 4v motor =) that might help to know that.
Scott
Old Nov 1, 1999 | 07:33 PM
john's Avatar
john
1eyedjack
Nov 15, 2016 10:46 PM
Warrdan
Aug 22, 2015 06:00 AM
starweb
Jul 26, 2015 08:38 AM
tartar_sammich
29
May 31, 2015 04:17 PM
BigBlockF350
27
Mar 17, 2013 08:22 PM
