Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
New Compressor Help Needed!! Your Opinions Please!!
Old Oct 7, 2006 | 11:24 AM
BuffDaddy's Avatar
BuffDaddy
Question New Compressor Help Needed!! Your Opinions Please!!
Greetings All:
Looking at a new Porter cable compressor for the farm Shop.
Locally they have this Porter Cable compressor on sale for $379.00. Seems like a pretty good price. Would appreciate your opinions on this compressor ASAP. Below is the link to it.
http://www.portercable.com/index.asp?e=547&p=4701
BuffDaddy
Airborne Ranger Recon.
Brothers who share a bond the average person will never understand.
Class of 67
Old Oct 8, 2006 | 08:34 AM
DetailerDave's Avatar
DetailerDave
Make sure that the air delivery is sufficient for your intended useage. The specs indicate 9.7 scfm@90psi.
The compressor I have in my garage is rated 15.0scfm@90psi. 80 gallon tank. I use it to run an impact gun, various air tools and a sandblast cabinet. It does run steady with the blaster, tho.
Old Oct 8, 2006 | 08:54 AM
fordfaninIL.'s Avatar
fordfaninIL.
If you are going to use it alot, then I would look for a two stage compressor. You will get more life out of it. A good compressor is going to cost from $350-750.
Old Oct 8, 2006 | 11:01 PM
rebocardo's Avatar
rebocardo
For a lot of heavy use a 2 stage is best. Being one stage and oil less expect a lot of noise.
> SCFM Air Delivery @90 PSI 9.7
This is good, you need 6.0 CFM at 90 psi to do any real work with impact guns and light cutting and grinding.
> Regulator NO
> Gauges 1
You will need to add a regulator and a gauge, so count that into the cost and make sure it is easy to add (has a blocked port) to the compressor. The compressor should kick on at < 100 psi and stop at 135 with a tank rated for at least 150 psi.
GLR
Garage & Workshop
Nov 30, 2012 07:49 PM
carpenter547
Jul 16, 2010 07:28 PM
duramaximizer
6.4L Power Stroke Diesel
Nov 30, 2006 10:59 PM
tmyers
Offroad & 4x4
Sep 1, 2004 04:57 AM
