64 F100
Old Dec 15, 1999 | 07:56 PM
gsruben's Avatar
gsruben
64 F100
When half the world reads this everyone will know
either how new I am or how stupid I am,but here
goes anyway. I recently bought a 64 F100 that is about 1/3 finished. It has a 302 for power and a
tranny that matches it,three speed on the column.
Where do I look for engine numbers to find out
what year it is? (It's hard to buy parts when the
parts guy says"What yearis it" and I say I don't know but it's a blue truck. I need seals for the transmission but don't know what kind it is either. Where do I look for numbers?
Thanks for the help. Everyone seems very knowledgeable about their Fords. Maybe some day I'll make it,too.
Gary R.
gsruben@infocom.com
Old Dec 16, 1999 | 05:49 PM
oleblue70's Avatar
oleblue70
64 F100
well gary,try pulling off your valve cover,stamped around the rocker bosses should be a year, as for your tranny,there should be a tag or i.d. on it.model numbers.also more than likley your 302 is an older one,so if you need any normal parts just say it's a 70. it 9 times out of 10 will work.hope this helps .oleblue=
Old Dec 16, 1999 | 05:56 PM
Dill
Guest
Posts: n/a
64 F100
If you know that the engine and transmission are the original ones from your truck then you can look at the I.D. tag on the drivers side door of your truck. Then you can look these codes up in just about any shop manual for your truck. If you don't have a manual check your local library. Hope this helps!
Old Dec 16, 1999 | 06:25 PM
64 effie
Guest
Posts: n/a
64 F100
So what if its the single hardest year to find some parts for. And they switched the cab mounts,suspension, motor and tranny mounts,splash pans,you name it. It still has argueably the best looking grill of the whole 61-66 body run. Well I think so anyway ha ha ha
64 effie
Old Dec 16, 1999 | 06:50 PM
jowilker's Avatar
jowilker
64 F100
Dill, wake up, weren't any 302s in 64.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Dec 18, 1999 | 12:34 PM
John Gehrmann
Guest
Posts: n/a
64 F100
Nobby
Jul 11, 2012 09:17 AM
gsruben
Sep 6, 2001 12:23 PM
gsruben
Aug 25, 2001 08:28 PM
gsruben
Mar 20, 2001 09:09 AM
gsruben
Feb 4, 2001 01:48 PM
