255 V8
Old Mar 17, 2001 | 02:09 PM
gsruben's Avatar
gsruben
255 V8
Someone tell me something about the 255 V8. How do you i.d. it? I am told it looks like a 302. Are parts interchangeable? I think it came out for a couple of years from '80 to '81. Is that right? Any info would be appreciated.
Garyr
Old Mar 17, 2001 | 07:26 PM
BigBrownTruck's Avatar
BigBrownTruck
255 V8
A 255 or 4.2L is a debored 302 design. It's stroke is still the same as a 302 but the bore is reduced from 4" to 3.68". Apparently some iron was removed from the block to make them lighter. The heads have smaller Intake valves than 302 heads, but as long as you pay attention to compression ratio issues, you should be able to put 302 heads on a 255. I believe bolt on stuff like the water pump and oilpan, manifolds should interchange w/ 289,302 stuff. The casting numbers I have listed for the block and the heads are: EOSE-AE for the block and EOSE-AC for the heads, the heads have 55.4cc combustion chamber w/ 1.67intake and 1.45 exhaust valve sizes.
BBT
Old Mar 19, 2001 | 04:54 PM
gsruben's Avatar
gsruben
255 V8
Thanks BigBrownTruck
Now I have some checking to do. I wonder if a crank from a 302 and the flywheel and harm.bal. would mess this engine up? Got a vibration I can't figure out and I'm sure it's a 302.
Garyr
Old Mar 19, 2001 | 11:12 PM
BigBrownTruck
255 V8
You know if you were to put the balancer and/or flexplate-flywheel from an older 302 (pre82) on a newer 5L (post 82) or vice versa, you'd have a vibration problem. I know of a person who bought a replacement shortblock for his 79, put his externals on it and had a bad vibration. Turns out he was sold a later model 5.0L. When he put the proper balancer and flexplate on it the vibration went away.
BBT
Old Mar 20, 2001 | 04:37 AM
gsruben's Avatar
gsruben
255 V8
BBT
You've been driving my truck haven't you!!!
GaryR
Old Mar 20, 2001 | 09:09 AM
64 f100's Avatar
64 f100
255 V8
sand man
May 9, 2023 12:38 PM
blue2golf
1997 - 2003 F150
Sep 5, 2005 11:47 PM
55F350Dually
Flathead V8 & Flathead 6
May 20, 2005 05:45 PM
55F350Dually
Apr 2, 2005 02:56 PM
Dariand1
General Automotive Discussion
Mar 2, 2005 10:25 PM
