Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Pickle fork
Old Oct 5, 2006 | 07:55 PM
eigenvector's Avatar
eigenvector
Pickle fork
Might sound like a real newbie question, but what the heck does a pickle fork do? I know what it looks like, basically a tuning fork with a chisel end, but why? How would something like that help getting a ball joint out, or do whatever it is that a pickle fork does?
Old Oct 5, 2006 | 08:20 PM
85e150's Avatar
85e150
Aids in separating parts that are pressed together. Like ball joints, tie rod ends, etc. Crude but effective.
Old Oct 5, 2006 | 08:22 PM
Ford_Six's Avatar
Ford_Six
You hammer it in between the two parts held together by the ball joint, with the stud of the ball joint in the middle, and it wedges the two parts apart.
Old Oct 5, 2006 | 08:26 PM
CAFordDude's Avatar
CAFordDude
I would have guessed it was used for getting and or eating pickles. But then I ain't so smart...
Old Oct 5, 2006 | 08:38 PM
eigenvector
Thanks, I assume the actual ball joint goes in the middle?
Old Oct 5, 2006 | 08:41 PM
vman's Avatar
vman
They do the job well but usually rip the boot in the process.
Old Oct 5, 2006 | 08:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Pretty little colorful replacement boots are available at some parts stores and speed shops.
Old Oct 6, 2006 | 03:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
no Aaron, you are supposed to use a tie rod separator for spearing pickles out of the barrel.
Old Oct 6, 2006 | 09:23 AM
GLR's Avatar
GLR
The screw type rod separators work best if you have the room to get them in. I have had the aftermarket ("Help" section) split appart just hanging on the wall unwrapped. And be very carefull using pickle fork after a few suds, you might crack your front teeth.
Old Oct 6, 2006 | 11:12 AM
CAFordDude's Avatar
CAFordDude
Ok because I am a stickler for having the right tool for the job...
That to is good info as I do not need any cracked teeth, front or otherwise..
Old Oct 6, 2006 | 11:27 AM
frederic's Avatar
frederic
Much easier to torch everything out and install new parts
Old Oct 6, 2006 | 06:04 PM
tjc transport
i ain't rite
how would you know?? you use a plasma cutter.
