4.6 hard cranking and error codes
Old Oct 5, 2006 | 06:33 PM
Mustangponylx's Avatar
Mustangponylx
I have a 2005 f-150 with the 4.6 45,000 miles with difficulty cranking it. It will turn over fine. Just had codes come up PO300 and P0305. Any ideas on the fix without paying the dealership to go and tell me its cop's or injectors or just plugs ??
Old Oct 5, 2006 | 09:41 PM
Beast12's Avatar
Beast12
Welcome to the site. I am sure someone will be by soon to help you out. Enjoy the site.
-Matt
Old Oct 5, 2006 | 09:48 PM
Mustangponylx
Thanks! Glad to join the club
Old Oct 6, 2006 | 01:14 PM
spiggy769's Avatar
spiggy769
Not entirely sure But I believe that the PO300 is a Random misfire code and the PO305 is refering that the #5 cylinder is the one doing the misfiring.
I am not 100% but someone here can probably verify it for me.
Old Oct 6, 2006 | 10:05 PM
xtrm1stang's Avatar
xtrm1stang
you are right on the codes, possible a leaking injector causing a loss of fuel pressure and not allowing it to start, that will also set a misfire code
Old Oct 10, 2006 | 05:28 PM
Mustangponylx
If it is a leaking injector causing loss of fuel pressure shouldnt I be able to turn the key off and on a few times to build up fuel pressure and it start fine ?? Tried that didnt make any difference. Im lost!
Old Oct 19, 2006 | 03:38 PM
Mustangponylx
Took it to the local shop and had it diagnoist and was told that it was possible a faulty coil pack.
James Nelson
1997 - 2003 F150
Dec 20, 2014 01:03 PM
riverrat46
Feb 20, 2008 05:45 PM
Mr. G
Modular V8 (4.6L, 5.4L)
Jun 20, 2007 07:29 PM
78fordman
Feb 19, 2004 10:33 AM
