03 Expy Window Buttons
Old Oct 5, 2006 | 09:29 AM
mtnman64's Avatar
mtnman64
The front window & lock buttons seem to be losing the lighting under them. It looks like the panel over them on the door will just lift up. Has anyone done this before? Is it easy to replace the bulb, or is it even replaceable?
Thanks!
Old Oct 5, 2006 | 10:02 AM
shov76's Avatar
shov76
I don't think they are replaceable. I had mine off recently to clean the contacts because the window stopped working. I didn't see any bulbs, just a plastic dot that lit up. If you do decide to go into the buttons I'd encourge you to buy a small can of contact cleaner and pull out the entire assembly (real easy) and give them a cleaning. It's hard to believe that my "03" were so dirty that the window stopped going up by using the drivers controls.
Old Oct 6, 2006 | 11:22 AM
mojobaby's Avatar
mojobaby
that plastic dot that lites up is probably an LED (light emiting diode), but it may not be removable.
I agree with shov76, take it apart and get a can of cotact cleaner (radio shack or parts store) that may be the problem, at that point you may be able to see if the led is removable.
swagfu
Mar 26, 2017 07:59 PM
Neal Walton
Dec 17, 2015 08:21 PM
6 or 10
Aug 24, 2015 08:02 PM
Back265
Jan 19, 2010 08:07 PM
bohiaa
Appearance & Dress-Up
Jun 7, 2006 06:38 PM
