Plug misfire
Old Oct 4, 2006 | 12:40 PM
maceslin's Avatar
maceslin
Plug misfire
02 Explorer 4.0 L 6 cylinder
Just changed plugs last weekend with 125K on the old ones, looked pretty good except for gap.
Installed new plugs and now running very rough. Popped twos code this morning for Number three cylinder misfire and something about number three at low RPM.
Suspect that I have a cracked plug on number three cylinder, any other ideas.
So that I don't have to pull all plugs can someone confirm that number three is furthest back on passenger side (of course hte hardest to get at)
Thanks
Dave
Old Oct 4, 2006 | 02:06 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
did you use motorcraft plugs?
General Specifications Item Specification
Ignition System
Base timing 10° BTDC
Non-adjustable
Firing order 1-4-2-5-3-6
Spark plug gap 1.3-1.4 mm (0.052-0.056 in)
RH original spark plug AGRF22PG
LH original spark plug AGRF22P
New spark plug (either side) AGSF22PP
Lubricant
Silicone Brake Caliper Grease and Dielectric Compound D7AZ-19A331-A (Motorcraft XG-3) or equivalent ESE-M1C171-A
Old Oct 4, 2006 | 02:54 PM
1081's Avatar
1081
check and make sure you have the plug wires on correctly, then when your sure you do, check again.
Old Oct 4, 2006 | 09:50 PM
maceslin's Avatar
maceslin
Used Autolite double platinums. Only disconnected one plug at time and have verified good contact on all tips.
Did not use dielectric grease.
Thanks for hte diagram, as feared number three is hte difficult one to get at
Old Oct 4, 2006 | 09:56 PM
gunsmoke59's Avatar
gunsmoke59
i own a 96 F-250 (460 cid) I changed out plugs an did same thing..finally got the right plugs..it makes a diff if you dont use correct plugs
Old Oct 5, 2006 | 05:07 AM
marragtop's Avatar
marragtop
Did you replace the wires as well? With 125k you should consider it. Also, did you check the gap on the new plugs? Don't trust anything to be 'pre-gapped'. The plugs are easiest to get through the wheel wells.
Old Oct 5, 2006 | 09:42 AM
Parts Guy Wyatt
Former Vendor
I think most people will agree, use the Motorcraft plugs. They really are the best for Ford products.
Ed
Old Oct 5, 2006 | 10:03 AM
Bob Ayers's Avatar
Bob Ayers
I agree with the plug wire suggestion. The plug wires can be easily damaged when replacing the plugs.
Old Oct 6, 2006 | 02:15 PM
maceslin's Avatar
maceslin
completed
ended up swapping out number three plug- no differnce
Repalced all wire and solve dhte problem
Thanks fo rall the help
Race
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 1, 2016 03:36 PM
ranger_xlt39
1983 - 2012 Ranger & B-Series
Apr 15, 2015 07:02 AM
svo65
Modular V10 (6.8l)
Sep 10, 2011 08:33 PM
majboise
Apr 7, 2004 09:43 PM
