Hi all I'm looking for some info on how the pump fits to the tank. Some one in a parts store told me it was hard to do. I was hoping to find a link or some thing to give me some insight on how this is dun.
Thanks
Gator
Best to replace the whole thing as a unit - and do not use a standard puller for the pulley, or you will break it... you need that special PS pulley puller as far as I know. why do you want to replace only the tank? cracked? it's best to replace the entire pump in my opinion.
I would buy both, assemble them on a bench, and then install them in the truck. the problem is, that if the tank is cracked, and you just replace that, it will howl after a while, since air most likely has gotten in there, etc... just my 2 cents
Well I feel dummer than a rock!!
The pump and the tank are two differant peaces. There are two hoses that connect them. Replacing the pump was easy. I should have looked under her hood befor I started this. Well I have replaced the alternator power steering pump and there is still some thing squilling under the hood!!!! Can a idler roller squil like a bad pump or alternator??
Gator
Worse - but it is usually a different sound - the ford pumps are known for the "whine" more than the squeal - I hear more F150's do that than anything else - I'm fighting with this myself on my Explorer.
a "squeal" is exactly how I would describe a failing bearing on the idler - you can actually figure it out by using the old "hose to ear" trick - which will allow you to pin point where it is - some people use a long screwdriver which is much more dangerous to me... (the engine is running)
It could be the water pump too - I would look around that area too to see if you see the slightest bit of a leak - could be starting to fail.
If you're sure it's not the PS pump squealing, then consider the idler pulley. If that seizes up, it will spit the belt and then you need a tow. I suggest taking the belt off and spinning each pulley to try and isolate the problem.
I have a 96 explorer with the 5.0 and it had a squeal I thought was lots of different things. Turns out it was the camshaft position sensor. It was squealing something fierce until I tracked it down. I removed the serpentine belt and then ran the engine for a few minutes-don't let it overheat. Thats how I eliminated all the pulleys as the source. The shaft on the sensor engages with the camshaft and it was just covered in varnish due age I guess. Tried to clean up the shaft adn polish it out. That worked for a while, but it started again within a week. Finally just replaced it. Use extreme care when removing and replacing as you don't want to mess up the engine timing.
