New starter recommendations?
Old Oct 22, 2006 | 08:07 PM
Franklin2's Avatar
Franklin2
It will probably work fine as you have it. But theoretically, the less connections the better for the large leads. If you are pulling around 100 amps, even a very very low resistance can cause some voltage drop.
The best senario would be to buy a new battery + cable that is long enough to go from the battery to the large terminal on the new starter(Eric's suggestion).
Then come off the battery + terminal with at least a 10, possibly and 8 gauge wire, and bolt it to the old Ford solenoid large terminal were the bat + used to go. This will take care of feeding all the electrical in the truck, since this is the factory junction point for that.
Then do as you suggested, and run a 12 gauge from the large post on the other side of the Ford solenoid to the solenoid on the new starter(I think you said this was "ignition").
By hooking it this way, the 12 guage will be less affected by any voltage drop problems in the large wiring, since it will have it's own connection through the Ford solenoid, to the battery +, and the Ford solenoid should last forever, since it now only has to carry the new starter's solenoid load. And the large wire will have less connection points(or splices) and two less switch contacts to cause problems and resistance.
Old Oct 22, 2006 | 10:09 PM
MasterMarine's Avatar
MasterMarine
That makes perfect sense. I like your suggestion. I think I will change it to the way you recommend. I am sure I have the materials on hand to build up some more custom wiring.
Thanks for the suggestion and also for clarifying Eric's post for me.
dbail3
Electrical Systems/Wiring
Sep 18, 2014 07:07 PM
seth_85
Jun 19, 2013 05:16 PM
Vaokie1
Jun 25, 2012 06:04 PM
tenforty_2
Jan 1, 2010 12:46 PM
freddie
Jan 17, 2000 09:34 AM
