Non-Starting
Old Jun 21, 2012 | 01:19 PM
Vaokie1's Avatar
Vaokie1
Non-Starting
I been having this problem for about 6 months and have changed the following items (some twice):
Battery
Starter
Solenoid
Battery Cables
Coil
Starter Cable
Engine Ground
Distributer Cap and Rotor
Iginition
Ignition Control Box
My problem is once I change(d) these items my pickup would start just fine for a couple of days, then I would begin to notice that it would only fire when I let off the key while cranking and then it would sputter and occasionally start. Is this problem indicative of a bad pickup coil? Once it starts it runs fine, its just getting it to start before burning out starter or solenoid.
Thanks for your help
Cliff
1978 F100
302 engine
2wd
Automatic
Old Jun 21, 2012 | 01:25 PM
f5fordgirl's Avatar
f5fordgirl
Change your solenoid, or next time you crank it, check to see if you have fire comeing out of the solenoid from the I termanal.
Old Jun 21, 2012 | 01:54 PM
montana_highboy's Avatar
montana_highboy
Sounds like a bad connection/broken wire coming off the "I" terminal of the solenoid.
Jump a temporary lead from + side of battery to + side of coil and see if it starts.
Old Jun 21, 2012 | 02:26 PM
kobaltblue's Avatar
kobaltblue
Turn the key to "ON" DO NOT START...Go out and with a screw driver and jump the solenoid to make it turn over and pump the gas a few times to see if it fires...If it does its the ignition switch...If it does not pull off a plug wire to see if theres spark, If not try hot wiring around wiring directly to the box from the battery....That will rule out everything up to the dist and the ign box..
Letting off the key tells me its the ignition switch... Or a bad wire going into the body of the switch....But try that first.
Old Jun 21, 2012 | 03:45 PM
montana_highboy
When the solenoid closes there is 12v direct to the coil for starting, from the "I" terminal of the solenoid.
Since his truck wants to start when he releases the key to 'run' the problem is in that circuit.
It could be a bad connection/broken wire at the "I" terminal inside the solenoid or it could be the wire itself that runs from the solenoid to the coil.
Ignition switch has nothing to do with it as it only closes the starter solenoid, in this circuit anyway.
So if the starter is turning and the truck only fires when he releases the key to 'run', the problem is in the connection/wiring, or solenoid itself.
Old Jun 25, 2012 | 06:04 PM
Vaokie1's Avatar
Vaokie1
Put the jumper wire from battery to + side of coil and it starts like a champ. Now I need to trace where the wire goes to and replace it. I think LMC has the complete assembly for sale.
TheMonson
25
Aug 13, 2018 01:20 PM
rockittsled
Nov 2, 2014 06:54 PM
ford collector
Aug 14, 2012 09:49 PM
76rustbucket
13
Feb 2, 2004 07:45 PM
homer
Sep 20, 1999 11:36 PM
