hub seal help
Old Oct 3, 2006 | 07:54 PM
hedhntr's Avatar
hedhntr
hub seal help
Was told by the stealership that I neede hub seals they wanted 450 bucks, so is the job all that hard to do, do I need specail tools and where can I pick these up from? thanks
Old Oct 3, 2006 | 08:11 PM
MAKO314's Avatar
MAKO314
the front wheel bearings and seals are not servicable and will probably have to be replaced. I bought both of mine and done the work myself,the hubscost me 285.00 a peice and about 2 hours of my time. I hope this helps but this is the case if you are talking about the 4x4 front hubs
Old Oct 3, 2006 | 08:13 PM
cnd999's Avatar
cnd999
headhunter, if you have the factory vacuum hubs the Ford part num.4C3Z1K106AA for the o-ring seals and retaining clip for hub lock retention to wheel hub. I mistakenly bought these seals and didn`t need them with my manual hubs so can return them.
Old Oct 3, 2006 | 08:45 PM
hedhntr's Avatar
hedhntr
I knew the front hubs were sealed so I was thinking the rear ones. I dont know, you guys know how stealerships operate
Old Oct 4, 2006 | 05:32 AM
cnd999's Avatar
cnd999
Sorry, the wheel hub yellow o-ring gasket seal is pt#F81Z4A322AA but if they said you need hubs that`s another ballgame. Good luck! It`s not that hard of a job though.
Old Oct 4, 2006 | 07:58 AM
clux's Avatar
clux
The bearings are not serviceable, but the hub seals are. There is about $80 in parts to do both front hubs, plus maybe 2 hours labor on each side.
pgguru
May 28, 2014 08:05 PM
clux
Feb 17, 2013 10:23 AM
abranz
Nov 18, 2012 09:39 PM
Joe Finn
1997 - 2003 F150
Oct 15, 2006 06:55 AM
86diesel-
Mar 20, 2006 12:20 PM
