352?
Old Oct 3, 2006 | 07:34 PM
RangerTuff05's Avatar
RangerTuff05
352?
what kind of power does a 352 have? are they pretty reliable
Old Oct 3, 2006 | 09:06 PM
Bear 45/70's Avatar
Bear 45/70
352s came in several versions;
1958-60 4V 300hp@ 400
1960HP 4V 360hp@6000 (Mechanical Cam)
1960 2V 235hp@4400
1961-63 2V 220hp@4400
1964-66 4V 250hp@4400
Good motor? Yes. A little short on bore and stroke at 4.00" X 3.50" (a 360 is a .050" over 352). Block is the same basic FE block for the later engines.
Old Oct 4, 2006 | 10:37 AM
RangerTuff05
the only reason that i ask is that i found a 77 highboy with a 352 and i wanted to know if they were good. I know about the 351's but not alot about 352
Old Oct 4, 2006 | 04:05 PM
bertha66's Avatar
bertha66
A 77 should have a 360 in it, enless someone put in an older engine.
Old Oct 4, 2006 | 09:54 PM
slinger34's Avatar
slinger34
Don't be fooled by the 352 casted into right side ofthe block. Almost every Fe engine had this casted into them.
Old Oct 4, 2006 | 10:58 PM
GORDON-B-FORDIN''s Avatar
GORDON-B-FORDIN'
I have enjoyed my 352 in my slick, have a look if u want
https://www.ford-trucks.com/user_gal...128839&width=0
Old Oct 6, 2006 | 10:30 AM
RangerTuff05
well what does the 360 have for power. I was told that it came out of and older dump truck but im not sure of the age
Old Oct 6, 2006 | 03:02 PM
Bear 45/70's Avatar
Bear 45/70
A true dump truck 360 is actually an FT series engine and would be a 361. Different crank and several other things, plus very low compression (7.4 to 1, where a 360's has 8.4 to 1). I doubt it came out of a dump truck if it has any real go power. The 360 is a .050" overbored 352. Some of the 352 would be stronger than a 360 due to higher compression and better carburation.
Old Oct 8, 2006 | 10:14 PM
RangerTuff05
so how do i know what i have
Old Oct 9, 2006 | 01:33 AM
Bear 45/70's Avatar
Bear 45/70
The FT motor has a cast front timing cover on it. The FE has a tear drop shaped timing cover and is only about a foot high.
Old Oct 9, 2006 | 01:58 AM
Alvin in AZ's Avatar
Alvin in AZ
I got something messed up?
I thought the FE's quit in '76. :/
If so, and it's not and FT, but it has 352 on it...
...my money's on it being a 390 FE.
Alvin in AZ
Old Oct 12, 2006 | 10:00 PM
RangerTuff05
it came out of an older truck.... is seems kind of gutless though. did the 390's produce good power?
dinosaurfan
20
Feb 17, 2021 09:41 PM
elsmith
16
May 11, 2002 05:41 AM
xcopterdoc
Jan 21, 2002 01:25 PM
fordsnharleys
Oct 18, 2001 08:01 PM
BenS
Apr 27, 2000 01:14 PM
