89 Ford Bronco
Old Oct 3, 2006 | 04:44 PM
cowboy_eddie7185's Avatar
cowboy_eddie7185
89 Ford Bronco
All my lights work except one the parking light is out on the passager rear. Brake , turn, and emerg. flasher for that side works. please help
Old Oct 3, 2006 | 06:42 PM
fordinmudd's Avatar
fordinmudd
let me get this right you cant get your rear tail light on the passager side to go on?
Old Oct 3, 2006 | 06:45 PM
Franklin2's Avatar
Franklin2
Check and or replace the bulb. Check and or replace the socket. Make sure you have 12 volts on the brown wire when the headlights are on.
Old Oct 3, 2006 | 08:30 PM
cowboy_eddie7185
I have checked that and with the parking lights on I have no light on that side.
Old Oct 3, 2006 | 10:03 PM
Franklin2's Avatar
Franklin2
If you have voltage on the brown wire behind the taillight, and the bulb is good and the socket is good, then there is really nothing else it could be.
The ground must be good, or the other lights would not work when you turned the headlights on, or the parking light would only work with the brake light off.
Old Oct 3, 2006 | 10:08 PM
Purdue Offroader's Avatar
Purdue Offroader
did you make sure both of the wires inside of the light bulb light up....there should be two....one for the bright lights (brake,turn, flasher) and one for the dimmer lights (parking, tailights), one of them can break and the other one will still work just fine. I would put a new bulb in before i went any farther (unless you already have and i just misunderstood)
Old Oct 4, 2006 | 02:28 PM
cowboy_eddie7185
wiring problem 89 bronco
Yes I tried a new bulb but I only had the parking lights on not the headlights will this make a diference and I tested the wire in question with a test light and you said two wires but I only have three wires in going to the socket. I assume one is ground one is for brake and turn and the other is blue with a orange strip it is the one I have no juice on with the test light. The left side has juice on each wire when I put the test light to them. And just so I know we are on the same page this is rear lights not front parking lights.
Old Oct 4, 2006 | 04:33 PM
cowboy_eddie7185
It is fixed the wire was broke underneath at one of the connectors coming off the drivers side going over to the passenger side
abyars111
Nov 12, 2012 09:18 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
memphis_made
1997 - 2003 F150
May 5, 2011 02:24 PM
buckeyeplayer
Jan 29, 2008 05:35 PM
JNKDad
Dec 22, 2007 06:22 PM
