General Diesel Discussion
Accidentally filled with gasoline......oops!
Old Oct 2, 2006 | 08:54 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
A buddy of mine here at work just got a call from his wife. She accidentally filled his Duramax with gasoline and then drove off. She is now stranded on the the freeway somewhere in Houston. He was asking me what he should do (besides going to rescue her) and I thought I would turn to you guys. Is the motor smoked now? Is this going to be an expensive fix? Where does he start?
Old Oct 2, 2006 | 10:07 AM
fellro86's Avatar
fellro86
I would likely guess it is in big problems now... gasoline in a diesel is a very bad thing...
Old Oct 2, 2006 | 10:11 AM
Texas Outlaw
Not a liberal...
This is why no one drives my truck but me.
Old Oct 2, 2006 | 10:19 AM
fellro86's Avatar
fellro86
between the preigntion due to gasoline's lower flash point and the lack of fuel lubricity, it may be serious, but it could be just a matter of injectors and cleaning the fuel out, if it is still cranking, it has a chance at survival, but it sure won't do it any good.
Old Oct 2, 2006 | 11:51 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Being gas is a very dry fuel probably messed up the IP, burned a piston or two. Hopefully the computer shut it down and needs to be reset. But that is being optimistic at best. Worse case - get a new engine. Wish I could give better news but it is BAD news giving a diesel engine gas.
Old Oct 2, 2006 | 12:37 PM
Texas Outlaw
Not a liberal...
He left to go and rescue her and I haven't heard back from him yet. She made it quite a ways (about 15 miles) before the truck quit on her on the Hardy Toll Rd in North Houston.
I was thinking it cannot be good. With as far as she made it I bet there is some severe engine damage done.
Old Oct 2, 2006 | 01:40 PM
Pocket's Avatar
Pocket
Have it towed to a shop or your house if you plan to work on it yourself. Do not drive it anywhere.
You'll have to drain the fuel tank, as well as bleed out the fuel lines. Replace the fuel filter, and fill the tank with diesel. Also put in some diesel additive to help with lubrication.
After that, fire it up. You'll know in a matter of moments whether or not you have any lasting damage. It may smoke for a minute and possible clatter a bit louder, but after a minute it should quiet down and run like normal. If so, take it around the block and test drive a short distance. If all is well you are ok. If it continues to smoke, clatter louder than normal, run rough or whatever, you probably have at least injector damage, possibly more.
Good luck.
Old Oct 2, 2006 | 01:55 PM
drbalazo's Avatar
drbalazo
I had the same problem with my PSD. I just drained the gas out and filled it with diesel and changed the diesel filter. It started with a lot of smoke but after about 1 minute, it was all good to go. I dont know how it is with CHEVY engines but it sure didnt damage my ford.
Old Oct 3, 2006 | 01:13 AM
pud's Avatar
pud
I filled up my 96 with gasoline once, drove a couple blocks down and noticed it was laggin real hard...couldnt figure out what was wrong. Just happened to look over at my receipt and saw "bronze gasoline"!!! so I cyphoned out both tanks and filled them with diesel. Fired it up and let it idle a while, since it idled fine with the gasoline, and drove back to the hotel. Woke up the next morning and drove the 600km home. Truck runs fine, but I wasnt cruisin down the highway running on gas.
Old Oct 3, 2006 | 08:00 AM
Texas Outlaw
Not a liberal...
He is back at work today and the truck is down at the Chevy dealer. He had it towed straight there. They said they will call him sometime this morning with whatever they fo9nd out.
He says the wife is no longer allowed to drive the truck.
Old Oct 3, 2006 | 05:02 PM
MIKE1646's Avatar
MIKE1646
If it still works.
Old Oct 3, 2006 | 05:48 PM
bigredtruckmi
Veteran: Navy
This is from my wife. gas in a diesel daaahhh what was she thinking.
Old Oct 3, 2006 | 06:40 PM
BLK94F150's Avatar
BLK94F150
It'll be fine. You have no idea how often my fellow firemen put gas in the diesel ambulances. We always have them towed to the dealer, but nothing serious is every hurt. Except pride.
Mike
Old Oct 6, 2006 | 11:26 AM
Mustangdriver's Avatar
Mustangdriver
Any update on this yet?
Old Oct 8, 2006 | 05:11 PM
nobrandx's Avatar
nobrandx
This happened to our 2004 Excursion, our recruiting staff had done the same thing, all we done at our shop (I work at a Vehicle Maint. shop) is like a previous post had mentioned, dropped the tank, emptied the gasoline, drained the fuel lines, replaced all fuel filters, filled it up with some fresh #2, added some stanadyne and went from there and it hasn't missed a beat since, hopefully the duramax wasn't toasted, those things ain't cheap.
