Diff problem
Old Oct 1, 2006 | 08:43 AM
Rickdj's Avatar
Rickdj
Diff problem
I started out just replacing my [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]axle [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]shaft[/font][/font] in my f150 8.8 rear end and now i have both pin gears and the center bolt out and cant seem to get them back in. The side gears are too far in so the center pin wont line up.
i noticed some broken dime sized pieces at the bottom of the dif that might have come from the side the base of the side gears but i am not sure. Ther were no metal particles or damaged teeth on any of the gears
Any advice on puting this back together would be appreciated
Old Oct 1, 2006 | 08:56 AM
RTM's Avatar
RTM
The spider gears that the cross pin goes through need sto be put in from opposite sides of the carrier and rotate the axle until they both end up in the center. This is much easier with two people but one can do it them selves.
Make sure the hardened washers are kept behind the spider gears or they will cause damage to the carrier in not time.
I like to clean the cross pin bolt and bolt hole so they are free of any oil and use a blue loctite to keep the bolt from backing out on you later.
As for the damaged dime shaped pieces I have no clue what to offer without seeing a pic of what you speak of.
Old Oct 5, 2006 | 10:09 PM
Rickdj's Avatar
Rickdj
turns out they were the tabs from the clutch packs which broke off. I have to replace those as the were causing the side gears to come in too far which was part of the reason the gears were so tight going back in.
Thanks for the assist.
Old Oct 6, 2006 | 02:56 PM
alz's Avatar
alz
I just did this also.
https://www.ford-trucks.com/forums/5...?highlight=alz
