Radiator Support Shims?
Old Sep 29, 2006 | 10:01 PM
cujo8's Avatar
cujo8
I am rebuilding my 77 F150 and I am replacing all the cab and radiator support bushings. I noticed in the LMC catalog that they show 6 shims are required for the radiator support (3 on each side). My truck did not have any shims under the radiator support when I dissassembled it, but I know the front end sheet metal has been replaced from being in an accident I'm guessing. So my question is are the 6 shims required or do you only use them as needed to align your front sheet metal? How many shims did you guys who have done this before find? Is there any trick to knowing how many shims I am goint to need? Thanks.
Old Sep 29, 2006 | 10:55 PM
mark a.'s Avatar
mark a.
You would only put shims in if you needed them. They make the fender align with the door.
rswhitmore
Oct 15, 2014 05:14 PM
Thumper19
51
Feb 2, 2012 10:46 PM
TheWiz427
Dec 18, 2008 01:48 PM
Hodgie5
Aug 12, 2004 09:50 AM
