54 Radiator support question
Old Dec 16, 2008 | 02:08 PM
TheWiz427's Avatar
TheWiz427
Ok i need enlightenment, I'm getting ready to put the radiator support back on and i have the support kit with new bumpers and two shims and bolts. What i need to know is if i use both rubber shims or just one, Also if the two outer bumpers are supposed to sit on the frame. When i pulled this off it had a small rubber shim under it and no rubber on the bumpers so i'm not sure how everything is supposed to sit.
Old Dec 16, 2008 | 05:37 PM
TheWiz427's Avatar
TheWiz427
Anybody know?
Old Dec 16, 2008 | 06:40 PM
Lakotas53's Avatar
Lakotas53
I am about ready to do the same install and was looking on the mid-fifties site. Looks like there is a rubber shim on each side but someone will come along that has done this and give you more info. Here is a bumb back to the top.
Old Dec 17, 2008 | 05:53 AM
TheWiz427's Avatar
TheWiz427
Thanks. It's going on today i guess the way i think it should go.
Old Dec 17, 2008 | 06:04 AM
jaye's Avatar
jaye
The rubber bumpers sit on the frame so the rad support will hit it when the truck dips left/right. The pads I may not be correct but this is how I put mine like this
(1) radaitor support
(2) rubber insert
(3) core support (frame)
(4) rubber insert
(5) then the metal insert
Old Dec 17, 2008 | 02:46 PM
TheWiz427's Avatar
TheWiz427
Well the way i put mine in is the bumpers are just about sitting on the frame and i have one rubber insert between the frame and core support and it's bolted together. Hope thats it, Seems firm enough.
Old Dec 17, 2008 | 07:44 PM
jaye's Avatar
jaye
I just checked Midfifty catalog there is a drawing on how it suppose to be installed its the same as I mentioned however, pictures beat directions anyday.
Old Dec 18, 2008 | 06:53 AM
TheWiz427's Avatar
TheWiz427
I saw that but their kit has a metal plate as where the kit i have doesn't. Also my radiator support has threaded inserts so the bolts thread into the support. I just ran the nuts down on them to help lock it in place. How much space is between your bumpers and the frame? Mine only have enough space to slide a business card through.
Old Dec 18, 2008 | 12:51 PM
erinaldi's Avatar
erinaldi
Sounds like you're on your way to doing it correctly. (See page 121 of Mid-Fifty). I did this two months ago and I found that I had to go back and loosen every bolt and nut I had tightened on the radiator support in order to get the remaining pieces(upper valance, etc. ) to line up.
Good luck!
Old Dec 18, 2008 | 01:08 PM
low54's Avatar
low54
I just took mine apart, Mid fifty has it right, if you like pics, the space is tight as you mentioned...my rubber was gone so the support was loose...Just in case, trust your using new carriage bolts...mine were all fused and i used my angle grinder to free the bolt from the nuts!...if you need any other assistance I have pics of the dis assemble
Old Dec 18, 2008 | 01:48 PM
jaye's Avatar
jaye
My radiator support had threaded holes but I drilled them out so I could bolt them from the bottom.My support is from a 55 but the frame is a 54 so it should be the same as yours.
skosler
Mar 12, 2026 04:46 PM
eddiey
Apr 21, 2009 01:05 AM
Tedybear
Jun 20, 2008 07:26 PM
r2000f150
Apr 7, 2008 06:47 AM
cujo8
Sep 29, 2006 10:55 PM
