66 F100 Stepside 4x4
Old Dec 12, 2000 | 12:41 PM
deerelovr's Avatar
deerelovr
My son has the above with original I6 4 speed and the transfer case seems to be wasted. Can he replace the engine and case with 302/351W and NP205 without difficulty and still use the same 4 speed? If so, can he use the I6 bell housing in this swap? I have never worked with Ford I6's, only V8's and John Deeres. He needs to get this back on the road.
Old Dec 12, 2000 | 03:02 PM
dinosaurfan's Avatar
dinosaurfan
deere- yes you can use the same bell housing on the 302/351's as you have now. You may need the perches and deffinitly will need the mounts for the V8. What T-case do you have now? DF
Old Dec 12, 2000 | 03:11 PM
deerelovr's Avatar
deerelovr
I am not positive of the t-case type but it has the old style tall shift lever with the grandma gear similar to the ones used in 1 and 2 ton ford trucks. Would this be what they call the New Process 435's?
Old Dec 12, 2000 | 03:57 PM
skip4274's Avatar
skip4274
49fordv8f4
Sep 22, 2022 05:35 PM
mendoAu
Apr 9, 2017 10:44 PM
250sampson
1978 - 1996 Big Bronco
Nov 7, 2010 08:19 PM
ford141
Dec 8, 2006 07:49 AM
troy payne
Jun 25, 2004 08:07 AM
