Trans extender
Old Apr 8, 2017 | 09:02 PM
mendoAu's Avatar
mendoAu
Trans extender
I don't want to appear lazy but I can't narrow my search down to a reasonable amount of threads....so... (I'm not transmission/transfer case literate, HA!). My neighbor just had a malfuntion in his 1972 F250 4speed w/ a 390 ci. engine with the "housing/yoke?" connecting the borg warner 1345-21 to the 4 speed transmission. Could someone tell me what it is called. One of the ears broke. He does not know the history of this truck and I'm beginning to think that not only the transfer case but also the engine has been swapped. He pulled the tag off the transfer case and here's some #'s :
3J006 1345-21
119208 E3TA-GB.
Like I mentioned,, I don't mind searching for an answer, just hoping for a push in the right direction.
Thanks for any input.
mendoAu
Old Apr 9, 2017 | 09:52 AM
orich's Avatar
orich
Sounds like you talking about the output Universal Yoke.
Count the spline teeth the width the u-joint and cup width when ordering one.
Or take it the yoke to a driveline shop.
PS TELL HIM TO BUY A MANUAL BOOK SO HE CAN LEARN!
This how we learned..
Orich
Old Apr 9, 2017 | 10:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
My neighbor just had a malfuntion in his 1972 F250 4speed w/a 390 ci. engine with the flange connecting the borg warner 1345-21 to the 4 speed transmission.
3J006 1345-21
119208 E3TA-7A195-GB =
Borg Warner W1345 Transfer Case: 1983/86 F250/350 4WD
E1TZ-7B214-A .. Flange-Front Output & Flange-Rear Output / Obsolete
FEYER FORD in Edenton NC has 1 = 252-482-2144.
Old Apr 9, 2017 | 11:25 AM
RichS2659's Avatar
RichS2659
Actually I think he needs the adapter housing between the T-18 or T-19 trans and the transfer case as it is a married case, not like the old divorced Dana 24 and NP 205 cases.
Old Apr 9, 2017 | 12:33 PM
NumberDummy
E3TA-7A195-GB T/C is from a 1983/86 F250/350 4WD
E1TZ-7B214-A flange is shown in pic and listed under E3TA-7A195-GB for the front and rear output.
Since the T/C has been swapped, has the trans also been swapped? 1967/77 F250 4WD (High Boys) would have had a divorced T/C originally.
Old Apr 9, 2017 | 07:49 PM
RichS2659's Avatar
RichS2659
3J006 1345-21
119208 E3TA-GB.
mendoAu
Is this what you need? And do you have a Borg-Warner T-18 or T-19 4 speed? Or a NP-435 4 speed?
https://www.onlinetransmissionparts....01-566-010.htm
Old Apr 9, 2017 | 10:44 PM
mendoAu's Avatar
mendoAu
Yep, that's the part. ( 4x4 Adapter Housing for Ford Borg Warner 4 Speed (T18/T19) )
Thanks...now it's time to crawl under that puppy and locate the trans. ID. and see if I can find a number/ID on the ADAPTER HOUSING. Great time of year to do this...been raining here in Oregon for months and just the proper amount of mud to contend with.
Thanks to all....and this site has more knowledge than any book!! HA!
kalebc2
Apr 4, 2017 09:22 AM
teamwizard
Apr 14, 2003 02:52 PM
71and72F100s
Dec 29, 2002 01:46 PM
f4wdtrk
Jan 23, 2001 12:19 AM
