O-ring material?
Old Sep 28, 2006 | 11:47 PM
CheaperJeeper's Avatar
CheaperJeeper
O-ring material?
Since the injector O-rings rubber has such a tendancy to harden, get brittle, start to leak, etc, has anyone looked into getting o-rings made out of a better material?
I'm thinking something along the lines of silicone rubber. It is much more heat resistant than butyl rubber, and IIRC it holds up well to petroleum-based liquids.
Old Sep 29, 2006 | 12:34 AM
PLC7.3's Avatar
PLC7.3
This was posted many moons back on another page.......
So far my research (that means looking at one that I took off and measuring it against the supply house stock) the injector orings for my 7.3 are a -111 (7/16 ID /x 5/8 OD X 3/32 long). I have replaced the existing ones in place with new ones from a dealer
The ones I have put on are a viton compound. They seem to be too hard for the temperatures here. When they sit all night, one develops an air leak. I am going to replace them with a nitrile compound tonight. Good thing about knowing the engineering description (dash number) is that you can buy them from a bearing/oring supply house in several compounds for 1/6th the price of the Ford products. Same o'ring, just no overhead.
I hope that this helps anyone looking for replacement o'rings and not wanting to go to Ford for them. $.20 Versus $1.38 each....
Injector return cap O-rings E6TZ-9229-AA
Old Sep 29, 2006 | 12:39 AM
CheaperJeeper
Is Viton a silicon rubber? Some of the modern materials that are readily available today just weren't around in the 80's....
Let us know how it works out either way.
Old Sep 29, 2006 | 11:38 AM
Spectramac's Avatar
Spectramac
Viton is that orange/brown colored rubber you see on seals and needle valves. Pretty tough stuff.
We ordered a bunch of O-rings a while back from a supply house that just happened to call us one day. He sold us a huge bag of 111 rings for pretty cheap. He even sampled us some heavier rings that I tried on my own truck. They went on pretty hard, time will tell how long they last. I was worried about them spliting the plastic caps, but no leaks yet. I think it's been a couple years. He said the normal 111s were 70 series? The ones he gave me to try were 90 series. Not sure where to get 'em locally.
Old Sep 29, 2006 | 01:22 PM
PLC7.3's Avatar
PLC7.3
Viton® is a synthetic rubber and fluoropolymer elastomer commonly used in o-rings and other moulded or extruded goods. It is a trademark of DuPont Dow Elastomers L.L.C.
http://www.pspglobal.com/pictures-of-colorado.html
Old Sep 30, 2006 | 12:46 PM
Tom D's Avatar
Tom D
o-ring material
So what you are all saying is the nitrile compound is the best? Is this part #E6TZ-9229-AA the nitrile compound or something else and do I get this at Ford or at a o-ring supply house? I live in HOT climate. Don't worry about cold. I am having trouble with air in system probably around the filter and injector pump so I have been paying close attention to your posts concerning air getting into return lines. I have however been a little foggy as to your plugging the line on the filter. Is there some kind of check valve that can leak air into system? Any help with this problem will be GREATLY appreciated.
93 F-250 7.3 Banks Sidewinder (turbo,exhaust,etc.) E-40D
Old Oct 1, 2006 | 01:27 AM
CheaperJeeper
OK, but what are the temperature properties of Viton? Is it as heat resistant as silicon rubber? Sounds like tough stuff, but the big question is does it harden up when exposed to heat (and loose its seal), and/or does it shrink with cold temps - also causing it to lose its sealing properties.
Old Oct 2, 2006 | 01:32 PM
Hamberger's Avatar
Hamberger
Viton has been a very common sealing material in the Refining and Oil and Gas Industy for years.
Many folks who has started running there trucks on Biodiesel recommend viton over the Ford stock O-rings. Personnally I have run Biodiesel (B40) for about six month and have not seen a need to switch yet.
If you got the opportunity to upgrade now would probably be a good time. With the fuel industry moving the way it is all diesel fuels may be required by law to contain a small amount of Biodiesel (5-15%) in a few years to raise its Cetane value and get lower emissions.
Seb....
Old Oct 2, 2006 | 06:23 PM
Tom D's Avatar
Tom D
Smile o-ring material
Thanks for the info. I was planning on changing them now because of air in the fuel system, but thanks to all of you and your suggestions, I was able to cure the problem by plugging the line from the filter to the injector. Thank you ALL very much. I was ready to take it to a mechanic to fix the problem. "KA-CHING" This is a great forum. I'm glad I found it and am part of it.
Old Oct 2, 2006 | 07:01 PM
bobpat204's Avatar
bobpat204
www.marcorubber.com
this web site has a material comp.page of almost all modern o rings (what they are made of temp extrems,what the withstand and wont ,psi.ect) good site for ref info on o rings
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 21, 2019 01:40 PM
ArcticF250
Apr 24, 2010 09:50 AM
kenneBF250V10
Oct 15, 2008 09:11 AM
katbird704
Sep 27, 2008 05:48 PM
Raceallday
Nov 29, 2004 08:15 PM
