removing the a/c compressor
Old Sep 28, 2006 | 10:34 AM
87ford's Avatar
87ford
has anyone tryed to remove their a/c compressor from their 5.0 yet? if so what size belt works? i dont use it and it should make a little more power without it i think
Old Sep 28, 2006 | 10:44 AM
low92flareside's Avatar
low92flareside
Because of the way the belt is routed, you'll have to put in an idler pulley and use the same size belt. not sure how much power you can expect from this. when the AC isn't running its basically an idler pulley anyway. idler pulley may have a little less drag, but not much.
Old Sep 28, 2006 | 01:13 PM
david00f150's Avatar
david00f150
I agree. When the clutch is not engaged on the compressor it is just like and idler pulley so it really defeats the purpose.
Old Sep 28, 2006 | 05:08 PM
frederic's Avatar
frederic
Idler pulleys put more load on the engine than an AC clutch that's not engaged.
Why?
AC Delete idler pulleys use cheap, crappy bearings that allow dirt in, whereas the AC clutch bearing is a precision bearing.
Of course we're talking about a .000001 HP difference in draw.
kountzecobra
Feb 22, 2016 08:38 AM
R T
Jul 30, 2015 10:45 AM
Ridenred333
Jul 18, 2015 04:58 PM
Whitey Ford
Dec 30, 2013 07:47 PM
TexxinOhio
1978 - 1996 Big Bronco
Jan 21, 2004 11:54 AM
