Oil Temp Light
Old Sep 27, 2006 | 09:59 PM
fordlovin's Avatar
fordlovin
Oil Temp Light
When I went out and started my truck the oil temp light stayed on for a couple of seconds and then went off. It's kinda cold out, but when I turned it off, after driving it a few miles and it was completely warmed up, and then started it back up the light stayed on again for just a couple of seconds. What's going on?
Old Sep 27, 2006 | 10:09 PM
Uzumati's Avatar
Uzumati
Temp?? Are you talking about the Low Pressure warning light. Check Oil level. Or coul dbe a sign of a weak LPOP
Old Sep 27, 2006 | 10:24 PM
fordlovin's Avatar
fordlovin
Well, the light is red and it has the same symbol as the coolant guage does with an oil can under it. Is that oil temp?
Old Sep 27, 2006 | 10:39 PM
fordlovin's Avatar
fordlovin
I just check my oil and it is right at the top line on the dip stick.
Old Sep 27, 2006 | 11:29 PM
jtharvey's Avatar
jtharvey
It's a warning light for either low oil pressure or high coolant temp. Kind of dumb that they use one light for both. My light flickered a few times several weeks ago while driving, and I pulled the owner's manual out to check for sure what it was. Turned out to be a bad connection on my oil pressure sensor under the hood. Since I cleaned it, I haven't seen the light on again.
jamhh
Sep 19, 2014 10:15 AM
messeswithtrux
17
Mar 3, 2010 04:35 PM
marcia
1983 - 2012 Ranger & B-Series
Jan 1, 2005 05:34 PM
jda
Feb 25, 2002 06:14 PM
