check gauges light??
Old Mar 3, 2010 | 09:41 AM
messeswithtrux's Avatar
messeswithtrux
when i turn my key to warm up the glow plugs my check gauges light stays on, the only other light that stays on is the battery light. i dont ever remember this doing this so im wondering if this has something to do with my hard starts on cold mornings. i always thought all of the lights went out after a couple seconds. its either that or my oil pressure doesnt move until AFTER the truck is started, i always thought that gauge moved before ignition also. i just cant remember so i figured i would ask some that have proper running trucks to take a look for me. thanx
Old Mar 3, 2010 | 10:44 AM
bama29fan's Avatar
bama29fan
not 100% sure but i think all of mine turn off after a few seconds. I'll check at lunch
Old Mar 3, 2010 | 11:52 AM
messeswithtrux
thank you!!! thats what im thinking, which leads me to believe my batteries are crap which would be great news!! ill be waiting for the reply
Old Mar 3, 2010 | 11:55 AM
superduty4x4's Avatar
superduty4x4
Do the lights turn out when you start it? I can't say on the engine light, but with the key on and the engine off the battery light will stay on.
Old Mar 3, 2010 | 12:22 PM
messeswithtrux
yeah, all the lights come on, then the only 2 to stay on are check gauges and battery. my oil pressure also doesnt move before i start or when cranking, i had thought i read somewhere that the oil pressure gause moved when the key was either turned to the on position or when cranking. mine doesnt move until the truck is running, then it moves right up to where it should be.
Old Mar 3, 2010 | 12:28 PM
87beater's Avatar
87beater
If your oil pressure gauge moves before you start your truck...I'd be worried...
You can't have oil pressure until the engine starts and the pump builds pressure, so what you are describing with your pressure gauge is perfectly normal.
Old Mar 3, 2010 | 01:12 PM
messeswithtrux
i meant while cranking, sorry
bama29fan's Avatar
bama29fan
only light that stays on was Batt. all others cycled and went out within a few seconds....well before the wait-to-start light went out.
Old Mar 3, 2010 | 01:49 PM
superduty4x4
Probably time for a new alternator for you then.
Old Mar 3, 2010 | 02:05 PM
bama29fan's Avatar
bama29fan
sorry...this was with the key in "on" with the engine not running. when i crank her up all lights go out. I was responding to the original post asking what lights are supposed to stay on.
Old Mar 3, 2010 | 02:11 PM
superduty4x4
FUBAR, my bad.
Old Mar 3, 2010 | 02:45 PM
bama29fan's Avatar
bama29fan
FUBAR, my bad.
LOL...i wasnt clear
Old Mar 3, 2010 | 02:54 PM
messeswithtrux
damn, your check gauges light goes out before you fire it up? thats wierd, i dont know what its telling me to check with that light, the only other one lit up is the battery one, but all of them go off after i start the truck. i really dont want to take it to the stealership just to plug it in and tell me, anyone have any ideas? why is it telling me to check gauges when the only one on is the battery one?
Old Mar 3, 2010 | 03:03 PM
Franko72's Avatar
Franko72
Molon Labe
I just checked mine, my oil and battery light stay on until I crank it over. I have one year old batteries, and no charging probs.
The 97 here at work also has two new batts, and a new alt and the battery light also stays on until you crank it.
Old Mar 3, 2010 | 03:17 PM
guitarpicr's Avatar
guitarpicr
Mines the same - Battery light stays on till it starts then goes out once it starts.
